Question about Gateway Computers & Internet
How to do a System Restore on a Gateway TA6 ?
  • Gateway Master
  • 4,806 Answers
Click on the start menu/orb, select all programs, accessories, system tools. System restore will be in that list.
Good luck.
Posted on Jul 01, 2009
Sound driver ta6 gateway
heahttp://drp.su/drivers/notebooks/?v=Gateway&m=M285-E&id=6492&l=enr is a bundle download link;
Mar 17, 2015 | Gateway M285-E Notebook
Gateway login
Getting locked out of your Gateway computer can be frustrating, especially when you have school or work deadlines.
You can get locked out of your Gateway computer in cases where a password-protected screensaver became corrupt, or if the you have set the default screensaver to use a screensaver that does not exist.
Gateway computers come with Microsoft Windows XP and 2000, including the professional versions of both.
Knowing how to unlock your a Gateway computer can save you time and irritation.
Press the "Ctrl," "Alt" and "Delete" keys on your keyboard simultaneously to unlock your Gateway computer.
Type the last logged-on user's login information and click "OK" if you see a locked computer message along with "Only domain/username or an administrator can unlock this computer."
Press the "Ctrl," "Alt" and "Delete" keys once again when you see the Unlock Computer window disappear.
Log on as usual.
Method 2
Shut down the locked Gateway computer by using the Microsoft Windows Resource Kit Shutdown tool. This tool shuts down and restarts a Windows 2000- or NT 4.0-based Gateway computer. Note the dialog box that comes up called System Shutdown.
Wait for the shutdown timer to run out and see the Welcome to Windows box displayed on the screen.
Press "Ctrl," "Alt" and "Delete," which unlocks the computer.
Log onto your Gateway computer normally.
Method 3: Backup, Modify and Restore the Registry
Click "Start" and "Run," then type in the command below in the field box exactly as printed:
%SystemRoot%\system32\restore\rstrui.exe
Click "Create a Restore Point," then click "Next" on the Welcome to System Restore page that appears.
Type any name for the restore point, then click "Create" on the Create a Restore Point page. Click "Close" after creating the restore point.
Perform this procedure before you make changes to the registry, just in case you make an error; otherwise, incorrect registry changes could create serious problems with your computer.
Click "Yes" if you receive a prompt to turn on System Restore at this point.
Clear the "Turn Off System Restore" check box by clicking on it, then click "OK," and repeat.
Click "Start," then type "regedt32.exe" (without the quotes) in search field box to modify the registry and unlock the computer. Press the "Enter" key on your keyboard.
Locate the scrnsave.exe value under the registry key below:
HKEY_USERS\.Default\Control Panel\Desktop
Click "String" on the Edit menu, type "logon.scr" (without the quotes), then click "OK."
Look for the ScreenSaverIsSecure value, then click "String" on the Edit menu, type "0," then click "OK."
Quit the Registry Editor
Click "Start" and "Run," then type the command below exactly as printed to restore the registry, then click "OK":
%SystemRoot%\System32\Restore\Rstrui.exe
Click "Restore My Computer to an Earlier Time" on the Welcome to System Restore page, then click "Next."
Note your computer may already be selected to restore to an earlier time--in this case, just click "Next."
Click the system checkpoint on the Select a Restore Point page.
Click "Guided Help (Registry Backup)," then click "Next" on the "On This List Select the Restore Point" area.
Click "OK" if you see a System Restore message listing all the configuration changes it will make.
Click "Next" when you come to the Confirm Restore Point Selection page.
System Restore will now restore the Windows XP configuration you had at an earlier time, and then it will restart your Gateway computer.
Log onto your computer as usual, and then click "OK" when you see the System Restore Confirmation page.
Nov 18, 2013 | Computers & Internet
Gateway desktop critical error code
Which operating system ???
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
How can I restore my computer to factory?
There is a folder called Gateway on your system and is NOT hidden. Open it and there should be a folder that contains the system restore to factory specs there.
Nov 03, 2012 | Gateway DX4200-09 PC Desktop
Gateway ta6 mass storage controller driver
http://support.gateway.com/us/en/product/default.aspx?tab=1
input your model and the driver that you need download it and restart computer and away you go. John
Apr 15, 2012 | Gateway Computers & Internet
How can i reset my Gateway Netbook?
Hold down ALT Gr or Alt Car and tap the F10 when the system turns on , you will get recovery console , select restore system to factory defaults ,
if system is booting into windows go to Start Menu - All Programs- Gateway - Recovery manager - restore - restore system to factory defaults ,
this will wipe all the documents , pictures everything in the system
Jul 07, 2010 | Gateway LT2030u Netbook
Gateway 835GM Media Center Computer: I had to do
Here a link that may help you: http://support.gateway.com/s/SOFTWARE/Medialess/MLXPMC0/MLXPMC0sl.shtml
But you can restore the back up file by going to Start> Programs > Accessories >System Tools and Run Backup. Pick the restore option find your file and restore it
Dec 12, 2009 | Gateway 835GM (835GH) PC Desktop
My laptop doesn't boot up. Only get a black screen.
have you tried connecting to an external monitor?
Oct 15, 2009 | Gateway M285-E Notebook
System Restore disk
is there not a 2nd partition on your computer with the restore files on? If there is try pressing Alt + F10 when the gateway screen appears on boot. This will restore you computer to the factory settings.
Before restore starts it will ask you for a password, this would have been user generated when you first got the computer. If you don't know the password, press enter - maybe you didn't enter one to begin with and this will bypass it, or it may give you a hint as to what the password is. Or just try typing in admin. (if you don't remember your password - I don't know what to suggest, except it may be the same password you use for your user account or did use when you first got the computer.)
I have tried looking for restore disks for you and came back with nothing.
I hope this helps
Nov 14, 2008 | Gateway MT3705 Notebook
Computers & Internet Logo
308 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
