Question about Scotsman Ice Maker CM3 30inW Cubed Ice Machine 900LB
A continuous grinding sound on my Scotsman DCE33A
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
I would suspect the water pump is making this noise. If it is, there is no repair, you must replace it.
Posted on Jul 14, 2009
Water dispenser takes a long time to shut off.
Sounds like the water valve needs to be replaced. If you move your cup and it continues to pour out water valve is, leaking through
May 27, 2015 | Scotsman MDT5N40W-1J Touchfree Water...
Scotsman ice machine continuous water flow
If you have a continuous flow during operation you need to replace the supply water solenoid valve. These valve are available at most cc dickson supply houses or through your local refrigeration tech. They will need you model number.
Apr 20, 2014 | Scotsman Refrigerators
Scotsman DCE33A-1WB not draining
Check that Ice cubes are freeezing completely before dumping into tray.
Check that spray nozzle isn't inadverdantly clogged and spraying water everywhere.
Check that water inlet solenoid is actually closing and not leaking water into bin.
Check thermostat for the bin not working properly, frozen over or something.
Oct 31, 2012 | Scotsman Refrigerators
Scotsman DCE33A-1WB Residential Ice Machine Problem
Making good ice. Could be cube size control. Could be a weak compressor. Also these machines are household and meant to run in air conditioned space.
Aug 02, 2010 | Scotsman DCE33PA1BC 15in Built-in...
Scotsman icemachine m# DCE33A-1WB ice cubes are hollow
There is a cube size thermostat that energizes the timer. If it has been energizing early try a thicker setting on the cube size. If still gives problems ... your trouble was back in Feb I assume in cold weather.. If the machine is not in a room where the temp stays above 65'f this can also cause premature harvesting as you discribe also. Also if you are loosing water from the water curtian not sealing off it will cause the problem you discribe because the water is dripping off and out before it can freeze. Any futher questions please post. If this helps you understand your trouble please rate me as high as yuou can, thank you for using fixya
Feb 11, 2009 | Scotsman DCE33PA1BC 15in Built-in...
Odometer 119,000 miles-on dive at 10mph short grinding sound in engine.
have you had your brake pads checked? you could be running metal to metal causing major damage. if this it the problem the noize is more noticable as you use the brakes, and makes a real grind just as you come to a stand still.
If you look at you rims you may see dark gray/black powder with matal flakes.this is the worn one do both sides.....
Jun 14, 2008 | 2001 Toyota Corolla
Kitchen Appliances - Others Logo
560 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
