WOULD YOU KNOW OF A PLACE WHERE I COULD TAKE MY SCANNER FOR SOMEONE TO PROGRAM IT FOR ME, IF YOU CAN'T HELP ME OUT.
SOURCE: programing for uniden bearcat scanner bc 144xl
danval, I looked up a pic of your scanner and it is pretty straightforward. If it is the 16 channel I was looking at, here is the step by step programming.
1- Push manual button to go to the channel you want to start programming.
2- Enter the freq number in.
3- Push the E button to enter it in the memory.
4- To review what you programmed, push the Review button.
5- Use manual button to step to next channel and start over from #2
That should get you started with the scanning hobby.
The scanner has a Priority button that when activated will stop scanning and go immediatly to the priority channel if someone keys their mic.
If you need freq's (or more of) for your area, go here and click on your state and county and it'll give you a complete listing.
http://www.radioreference.com/apps/db/
Hope this helps you out, let us know,, Mechanic
SOURCE: uniden bearcat scanner
The scanner was probably turned off and it forgot what frequencies were programed into it. Older scanners have a problem with retaining their memory when they are shut off. Most of the older scanners have a memory back-up battery that helps the scanner retain its memory. Check and see if this battery is still good. As for your frequencies, you'll have to reprogram the scanner. To put it in technical terms, some older scanners have what is called RAM (Regency Alterable Memory) and ROM (Regency Organized Memory), when you turn off you scanner, this memory is erased, along with your programmed channels. Be sure not to turn off your scanner unless you're willing to reprogram the scanner.
SOURCE: How to program scanner
Hi - You can download the manual from the link underlined in blue below:
BC60XLT-1
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Trouble programming my new Uniden scanner
Email me and let me know what area you live in and give me an idea of what you would like to listen to. I may be able to help.
elijam1
[email protected]
Assume that the computer structures in place to make networking attainable only once within the mail box least produces results. Observations from the networked computers are indication of malware program attempting to hamper regular functionality. Computers that have antivirus software programs allow ascertaining the media least default. Observe from the list of computer programs to perform antivirus program functions. What is attained with antivirus is recycling the entire programs into an area from where the remaining malfunction programs as quarantined for deletion. In a situation that the computer least has antivirus programs or malware program has caused an extensive malfunction with programs least performing requires referral to computer support experts.
