Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Mower cuts out
I have a 12hp 40in Murray mower. While I have the blades engaged it sometimes cuts out. IF I stop the blades then it runs fine. Just changed the fuel filter. I am also in need of a belt. (just broke on me this am) Went to a "lawn mower' man in town and they can't seem to locate the right one. I have searched online and nothing is coming up. What size do I need? Model number: 40710a Date: 1404
  • k_long38 Jul 04, 2009
    This is the model number on the mower. It is behind the seat. Model number: 40710A Date: 1404
  • 376 Answers
Your model number is fine. The belt number is 37x62, assuming it's the blade drive belt. The loss of power is probably coming from the carb. Sounds like a fuel delivery restriction. The carb needs to be cleaned/repaired.
Posted on Jul 05, 2009
    Problem Solver:
  • 5 Answers
First of all the numbers you have are not correct, please try again, secondly, it losing power because of a few reasons, carb needs adjustment, governor needs adjustment, or valves need adjustment, with the correct model number and type, I can help with the belt and the problem
Posted on Jul 02, 2009
Model 40808X14A. When blades are engaged, why does mower die?
Most likely something is jamming a blade.
Another possibility is the reversing safety switch is stuck which cuts the engine spark.
Apr 15, 2016 | Murray Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Why does engine stop when clutch released or blades engaged?
Make sure have a good battery when you start the blades on any lawnmower it need lots of power to get it going
Jul 17, 2014 | Murray Garden
When everi i engage the blades, the mover cuts off on 40
I still think its a seat switch issue, many seat switch block connecters have fail safes in them should they come away from the switch, it is difficult to by pass these as they will earth out as soon as you pull it away from the switch
Jun 03, 2012 | Murray Garden
Murray Select 16.5 hp OHV 42
is one of the blades bent?is one of the bearing s seized or binding
Apr 16, 2012 | Briggs & Stratton Garden
Hi, I have an older Murray ride on mower, small
Sounds like you have some sort of seize up problem in your deck assembly. Have someone help you with this check, start your engine, engage the blade or blades, and have someone watch the shoot from a distance to see if blade or blades turn. if not then your problem is in the area of top pulley and blade or blades. You may need to replace or loosen the pulley to blade shaft. Sometimes this part is repairable where you can replace bearings or bushings and sometimes the whole unit needs to be replaced. Look to see if there are grease fittings on this unit. Try oil anywhere it will flow down in between areas that may be seized and work on loosening up the pulley blade assembly.
If this doesn't help, go to some of your local mower repair shops, they may be able to sell you a used part. Remember to bring mower information with you so they can help you with the correct part.
I hope this has been helpful to you. GOOD LUCK.
Jul 19, 2011 | Briggs & Stratton Briggs Stratton...
I have a problem with my ride on mower. we need to replace the belt that drives a twin cutting disks on a Victa 4013TX but cannot find any diagrams to help.
4013 HT is a Victa with a 13hp briggs and stratton engine normally with a twin blade 40in deck. These were badge engineered Noma mowers and essentially equivalent to murrays made at the same time. Check diagrams for murray decks to find one with the same deck configuration.
Jan 08, 2011 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
303 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
