Question about Casio Exilim EX-Z85 Digital Camera
Every time i switched it on it shut down - Casio Exilim EX-Z85 Digital Camera
Mow for 30-60 min.mower shuts down. Sometimes you can mow all day.start goin up hills mower will shut down,about the second or 3rd trip.what's the problem?
Don't know what kind if engine you have but many have low oil shut down float switches inside the engine..when operating on hills or side if hills too long the oil will flow to the low side and the low oil switch will pick it up as low oil and shut it down..look for a small wire attached to the crankcase it most likely is that low oil switch..the next time this happens try disconnecting it and tape the end if the wire..try starting and run on the hill..it should not shut Down..just remember it is a safety switch to protect the engine from damage from low oil operation.try running the hills where the oil runs to the wire side of the engine..won't trick the low oil alert...Good luck..
Aug 08, 2015 | Garden
Tip
Charging of laptop while shut down may cause the corruption of operating system....
Charging of laptop while shut down may cause the corruption of operating system. While shut down battery level will store in the memory and in the shut down mode, if you are charging, it will store in another memory location. After that if you are switch on the system, it will compare both values. If both are not equal, it may be corrupt the operating system. I had affected by this. It wont happen in all times ..Once happened for me after that for knowing purpose i did the same for three more times.. But not the same result. Better to save laptop life, please dint charge while shut down
on Dec 05, 2009 | Computers & Internet
How do I tighten the ignition switch on my fxd?
If your ignition switch went loose or damaged you will have to change it ,then tighten. the screw that hold the IGN switch to the frame.
Jul 12, 2014 | 2006 Harley Davidson FXDCI Dyna Super...
My gen starts and runs for 1 min or so then dies restarts then dies again and again. if i start it under load ( turn on air con) it will run for 10 min then die allen
Is there a fault?? All UL listed generators including Kohler are required to lockout on a fault on shut down. This really sounds like a problem with your 2-wire auto start connection between your automatic transfer switch and genset. RDT model automatic transfer switch it is the 2 middle wires on the green connector and terminals 3&4 in the generator. close to run and open to shut down. Any open at any time will cause the unit to shut down. The 12 will shut down instantly upon an open because your 5 minute cool down is built into the transfer switch.
Jun 27, 2011 | Kohler 12 kW Emergency Power System -...
Hello I have a ASUS P5S800-VM Motherboard with no HD on it just some RAM,graphics card,the CPU and a sound card.My problem is that whenever I switch it on it will stay on for about 15 seconds then shut...
There is no help for this, sounds like board has gone bad in one spot.
Why not use Windows to shut down the machine, or buy a surge supressor with individual switches.
Lastly, you could change out the Mboard with a new one, probable cost $40-$80 if you DIY - plenty of instructons on the WWW
Feb 04, 2011 | ASUS P5S800-VM Motherboard
Engine cutting off after engaging the pto (mower deck) JD 317
its likely to be a switch playing you up try hard wireing the switch to see if it stops this cutting out first, do one switch at a time till you fine the one playing up
May 02, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Sep 18, 2009 | Acer Aspire 5920-6727 Notebook
Kill switch on Stihl BG 75 leaf blower not working
when engine cool,, spray wd 40 into the switch and work it a dozen or so times and clen it out
Aug 12, 2009 | Garden
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
Casio Exilim EX-Z85 Digital Camera Logo
22 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
Parshiv Luthra
Steven Wander
Steven Wander
Are you a Casio Camera Expert? Answer questions, earn points and help others
