Question about HP Pavilion dv6000z Notebook
I have HP Pavilion dv3 it is new and the problem is not charging it said "plugeed in,not charging" and when i remove the power it dies !!! can you help me plzzzzzzz thank you Toota
    Scholar:
  • 95 Answers
Hi
This is a very common problem with your model.
I tell you a series of steps for this.
1.take out the battery.dont connect the power cord.and push the power btton for a while so that all residue power is radiated.
then replace the battery,charge it and try start the machine again.if this doesnt work.
2.check the battery if its working fine.
if the battery is working fine then there is a problem with the charging IC on the motherboard.then
3.call the customer care and as your machine is new they will replace the motherboard for free.
if you find the solution helpful dun forget to rate me.
thnx
Posted on Jul 01, 2009
Dv3 black screen hp
Common issue with AMD based hp laptops.
Before doing any of the following from this point, please remove the ac adapter and battery from the unit.
Remove the battery and try to power on with the ac adapter.
With the battery and ac adapter removed, press and hold the power button for 30 seconds to a 1 minutes. We are trying to remove all the excess power from the computer, remember capacitors can still hold power. Now power on the computer with the battery and ac adapter.
Remove the ram and reinsert the ram. Sometimes the memory somehow manages to get a bit loose overtime. Try to power on the unit and see if turns on.
Try to connect to an external monitor to determine if its hardware issue by just connecting only with power adapter. If it works, then its screen and screen connection issue. If it doesn't work, then its motherboard/video problem.
Jan 17, 2014 | HP Pavilion Dv3-1075us Notebook
Pavilion dv3 power on and off continous and screen blank
Computer Keeps Rebooting - cannot access Safe Mode
1. Boot up with Windows installation CD 2. It will give you the option to use RECOVERY CONSOLE 3. Type chkdsk to check disk - this fixes bad blocks and moves data to another area. 4. When completed, remove Windows installation CD and reboot computer
Mar 01, 2013 | HP Pavilion Dv3-1075us Notebook
Problem with HP dv3 power cables.
Sounds like the charging board may be malfunctioning/shorting out inside the laptop itself causing these ac adapter failures.You really need to have it looked at before other it causes you motherboard to fail or any components connected to it.The power jack may be shorting as well which is attached to the motherboard
Dec 17, 2011 | HP Pavilion Dv3-1075us Notebook
Why does my HP Pavilion leak electricity?
Sounds like a power jack problem where the charger plugs in has a short or is touching other components near it.
Dec 16, 2011 | HP Pavilion dv3-2150us Notebook
Hi... how can i turn on the double click on touchpad ... my laptop is hp pavilion dv3
access control panel - select the mouse - select device settings - then the setting button - the rest is straight for for all the settings are displayed or hit default
Jul 04, 2011 | HP Pavilion Dv3-1075us Notebook
Pavilion DV3 not working on a car charger That is working flawlessly on other hp nc6400 laptop they both work great on the 220v standard adapter! Why isnt my laptop charging?? Please help
the 220 v power of cities has 25 Amper
has your inverter 25 A . of course not
so this is right that tow power sources have 220 VOLTS but the important matter for working
a device by power source is the out put AMPER plus output Voltage.
good luck
gorbesia
Jun 29, 2011 | Inverter 175 Watt Power Car Adapter for...
I cannot wake up my HP Pavilion dv3. blue power led flashes on and off and orange connection led too.
The display driver could have crashed, try holding the power button until the lights go off, and the hard drive powers down (you can hear the spinning stop) then try to power it back on. If that doesn't work, do a hard reset, which would be unplugging it from any AC power, and removing the battery and then reconnecting the battery before powering it on. Should this not work, i would say it's safe to assume the backlight is non functioning and a replacement would have to be ordered.
May 05, 2011 | HP Pavilion Dv3-1075us Notebook
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
How to remove power on password? model# HP dv3-1075us thanks
do u mean to remove the power to reset the password because u don't know the password, if this is the case, you need to remove the internal cmos battery inside on the motherboard then put it back in, this should reset the password, if you want the box that comes up asking you for a password, then you need to go into the bios, and look for password, and disable it, to go into bios, when your laptop is booting up look for press F2, F12, F5, to enter setup, each laptop is different, might be F8, F9.
Sep 24, 2009 | HP Pavilion Dv3-1075us Notebook
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
HP Pavilion dv6000z Notebook Logo
959 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
