Question about Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator
The door seems to be warped or tweaked in some way
The fridge is 10 years old, Model BX21TW, and the door seal was not sealing anymore so I replaced it. It still does not seal correctly. The door seems to be warped or tweaked in some way. Is this possible?
Your fridge is not level. If you level it you will find that the door was fine , it was the fridge that was tweaked because it was not level and sitting correctly. Use a level, shims, and/or the adjustment screws on the bottom.
Posted on Jul 28, 2010
Whirlpool et22dk refrigerator door suddenly seems "warped"...gasket won't seal, door doesn't close all the way
Check to door hinges for any movement and/or excessive ware, that old of a model this is not surprising.
Mar 02, 2018 | Whirlpool Refrigerators
I need a new door seal
Im afraid without the model number, which is located inside or outside on the back of your refrigerator, unless the model number tag/sticker/plate was removed or is not readable, finding the correct part would be extremely difficult.
Jun 28, 2010 | Bosch KUL1444 Compact Refrigerator
Liebherr Fridge Freezer fading door seal...
Look on e bay or kijji and see is anyone has one for sale That you could swap the door over .
Apr 06, 2017 | Liebherr KSv 4260
My Kenmore black mini fridge, door will not stay sealed shut
Got too much stuff in it.
Not level or is tilted forward.
Door is warped.
You keep opening it.
Am I getting close?
Sep 08, 2009 | Kenmore Refrigerators
Is it worth replacing a door gasket on a 25 year old freezer. It is a Kenmore 6. Upright. It does not seal tight anymore.
Is the door gasket torn?? if not try cleaning the rubber surface that makes contact with the metal portion of the fridge and clean the metal area also, because inside the rubber gasket is a magnet that helps the gasket seal properly.I've seen door gaskets range in price from $50.00-$100.00 so if thats the only problem it sure beats buying a new fridge for a whole lot more money.
Aug 25, 2009 | Freezers
Whirlpool Fridge/Freezer Door Seal Replacement. Model: ART 462/3
In short no as long as you get the correct seal type from a spares shop, or Whirlpool. Just make sure that it is straight and there are NO gaps or splits in it when you refit it. Usually these will come pre cut to size for the particular model of FF but you can also buy seal strip on a reel from many spares shops. Also when you have removed the old seal make sure that you use a degreasing cleaner to clean around where the old seal was located and make sure the area is dry before fitting the new one.
Aug 16, 2009 | Whirlpool Refrigerators
I believe that the seal around the fisher & paykel freidge door is too old, how much for replacing with a new one? The phenominon is-- it always has water inside the freidge at out side of the freezer....
Heya,
Normally if the you think the seal is too old than it is, I normally work on commerical fridges and the way that I check is too shine a torch inside the fridge and see if you can see any light gaps.
Where abouts are you and I will recommend someone to be able to change the seals. Normally they are about60-110 Supply or 80-120 supply and Install.
I would highly recommend getting someone in to change it for you thou as If done wrong it can warp the fridge door
Hope that helps
Jan 07, 2009 | Refrigerators
Amana Easy Reach AFD2535DE Bottom Freezer Refrigerator Logo
327 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
