Stripped? You can drill into the bolt or screw and then screw in a screw extractor (a left-handed screw). Sometimes, just drilling straight through the bolt relieves tension on the bolt and it is easier to turn.
Make sure to use the right sized drill bit if you go the screw extractor route. Extractors are available from auto parts stores.
spray at some liquid wrench on the bolts to remove corrosion that may have caused it to freeze (seize).
