You may try using the power switch on the TV itself instead of the remote. I have had trouble where the remote turn on doesn't work for the video, holding down on remote button longer seem to help.
Also you may want to try another input to the TV -so connect up input wires from your cable/sat to another one.
Although we would not be able to assist you with power issue you're having with your TV, I can assure you that the issue with your new HD Insignia TV not turning on has nothing to do with the DISH Network receiver you have connected to it.
Phillip Chang DISH Network Customer Service Representative
Hi red, My name is John. Welcome to FixYa. Go back and check your plugin connections. Make sure that they are making a good connection, some can be hard to make contact.....John
Since the power light is on the standby circuit is working fine and it is cutting up on powering the circuits, so either it could be a safety trigger or a failer. you will need to cross check by omission flow charting to find out if it is the Main power or the drive power.Check for dry joints or loose connection by tapping the main board to see any reaction to start up. good luck
if you want to narrow it down a bit-go to radio shack get some freeze spray.remove back-lay it down -use a blow dryer to heat each board till it goes out-then use the freeze to cool each board down till it works-do it a few times to make sure you get the rite board---now go to shopjimmys.com to find your board
