Question about Cell Phones
Games to china hi phone
Is it possible use wi fi and download games from my hi phone?
Do you have list of current Nintendo wi-fi connection-compatible software?
not sure if this link will help you outHow to get around the Wii Error Code 20110. Nintendo Wi-Fi Connection service for this software has been discontinued. Visit support.nintendo.com for a list of current Nintendo Wi-Fi Connection-compatible software. ... Anyway, it is still possible to play Mario Kart Wii or Super Smash Bros. Brawl online.
How to get around the Wii Error Code 20110 - St?phane Caron
https://scaron.info/blog/wii-error-code-20110.html... current Nintendo wi fi connection compatible software Google Search
Oct 26, 2017 | Nintendo Video Game Consoles & Games
Nokia Lumia Connection problem
cell phones ( mobiles) do not need wifi to work as a phone or e-mail receiver
you only need wifi for data download such as google and the like
Jun 02, 2017 | Cell Phones
How to install broadband to android tablet pc?
Share 01 Feb
2011 How to configure IP address of wi-fi connection on a Android Phone (Samsung Galaxy Tab) Posted in: Gadgets Tagged Under: Android, Galaxy, Samsung, Tab 7 Comments samsung_galaxy_tab-small-1.png
By default Androids phones (including Samsung Galaxy Tab) are set to automatically configure IP address, Gateway, Netmask and DNS address of wi-fi network.
But if you want to manually assign IP address, Gateway, Netmask and DNS address of wi-fi, here is how you can do. Method below is described for Samsung Galaxy Tab, but it will work for all Android phones.
  1. On Home screen, press Menu key.
  2. Tap Settings
  3. Tap Wireless and network.
  4. Tap Wi-Fi Settings.
  5. Press Menu key again.
  6. Tap Advanced.
  7. Enable "Use Static IP".
After you have enabled "Use Static IP", you will be able to manually assign and configure IP address, Gateway, Netmask and DNS address of wi-fi network.
Sep 23, 2011 | Android Apps
Why can't I download games from may android
Most tablets require a wi-fi connection to download games and browse the internet. Make sure your tablet is signed into a wi-fi network.
If it definitely is connected to wi-fi, or you don't know how to do that, you may want to give more details in your question, such as what model of tablet you're using and what version of Android it's running.
Sep 20, 2011 | Video Game Consoles & Games
How do you get the wi-fi on the ds
To set up a Wi-Fi connection on your DS Lite you have to use a Wi-Fi enable DS game. Wi-Fi enable DS games have a Wi-Fi symbol on the front of the box it came in. Simply play the game and you should see options to set up a Wi-Fi connection.
Apr 21, 2011 | Nintendo DS Lite Console
Hi my problem is there any solution to have a wi-fi on my phone?what can i do to have a wi-fi?
Hi niv13,
it is not possible to have Wifi on the phone.
you need to buy a phone WITH wifi built in.
i hope this helps, good luck!
Mar 16, 2011 | Cell Phones
C an not buy muisic,they said, i'm not connect to the internet
You have to ocnnect your iphone to internet first , Follow below step to connect to internet
When you use any Internet enabled application, iPhone does the following in order until connected:
  1. Connects over the last Wi-Fi network you used that's available.
  2. If no Wi-Fi networks you've used are available, shows a list of Wi-Fi networks in range. Tap a network and, if necessary, enter the password to join. Networks that require a password show ht1695_1.jpg next to them.
  3. If no Wi-Fi networks are available or you choose not to join any, iPhone connects over the cellular data network.
Note: You can be on a call and use Wi-Fi or 3G1 at the same time. Other cellular data networks are unavailable while you're on a call.
Wi-Fi
  • Wi-Fi is often faster than cellular data networks. Wi-Fi networks cover limited areas. iPhone can join AirPort and other Wi-Fi networks at home, at work, or at Wi-Fi hot spots around the world.
    When iPhone is connected to a Wi-Fi network, the Wi-Fi icon ht1695_2b.jpg in the status bar at the top of the screen shows connection strength. The more bars you see, the stronger the connection.
  • To see all the Wi-Fi networks in range, from the Home screen choose Settings > Wi-Fi. Tap a network to join it.
  • Many Wi-Fi networks can be used free of charge, and some require a fee. To join a Wi-Fi network at a hot spot where charges apply, in most cases you can open Safari to see a webpage that allows you to sign up for service.
For information about configuring Wi-Fi settings, see the "Wi-Fi" section of the iPhone User's Guide.
Note: iOS devices sold in China may use the term Wireless LAN (WLAN) instead of Wi-Fi. Not all China iPhone models support WLAN; see this article for more information.
Cellular data networks
  • Cellular data networks allow Internet connectivity over the cellular network. Check your carrier's network coverage in your area for availability.
    You can tell iPhone is connected to the Internet over a cellular data network if you see ht1695_utms_onb.png,ht1695_3b.jpg or ht1695_gprs_onb.png in the status bar at the top of the screen.
    If you're outside your carrier's network, you may be able to use a cellular data network from another carrier. Roaming charges may apply.
    Note: If not on 3G, while iPhone is actively transferring data over the cellular data network-downloading a webpage, for example-you may not be able to receive calls. Incoming calls may go to voicemail.
I hope , after this , you will be able to connect to Internet....
Thanks
Sandeep
Mar 14, 2011 | Apple iTunes
Why wont my htc trophy 7 install xbox live games it says to connect to wifi or pc i connect to pc but nothing happens help plz
If you see an error message saying "Connect to a Wi-Fi network or connect your phone to your PC to complete the download," disregard it. At this time, you can only download apps or games larger than 20 MB using Marketplace and a Wi-Fi connection on your phone.
Dec 09, 2010 | HTC 7 Trophy Cell Phone
I have a star c5000 wi fi tv phone but cant set up the internet , the phone has some setting on it for china mobile can anyone help please
CELLULARE STAR C 5.000 WI FI TV
NON RIESCO AD EFFETTUARE ABILITAZIONE A MMS
TM LA QUALE CONFIGURAZIONE NON SA FARE.
C'E' QUALCUNO CHE LO SA ?
Nov 09, 2009 | Lands Phones
Cell Phones Logo
55 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
