Question about Compaq Presario 700 470024-192 Notebook
Wheres both memorty slots in compaq700 presario notebook
How many memory slots are in presario700 notebook and where are they located
    Genius:
  • 1,341 Answers
According to my experience most memory slots are located at the bottom of the laptop and usually consist of 2 slots.You will probably need to unscrew 2 screws and once the cover is off you will see the ram memory.It's a very simple task and with the right tools it will take you less than a minute..Hope this helps and please do rate this solution.
Posted on Jul 01, 2009
  • Compaq Master
  • 13,433 Answers
Generally 2, on the bottom of the laptop or then under the keyboard.
I have HP Presario V2000. How to locate & find if I have SD card slot?
It has a 6-in-1 Memory Reader slot, on the right side close to the front edge. Taken from the HP manual.
Oct 08, 2010 | HP Compaq Presario V2000 Notebook
In built mics nt workin on compaq presario700
you have to find out what mic it is buy going to compaq website and install xp drivers for it, you will also get these from the website
Jan 20, 2010 | Compaq Presario 700 470024-192 Notebook
Have a presario 700 and want to upgrade the ram. Where is it located and how much can I add. tried pushing F1 when starting to get the screen that tells you
  • Maximum Memory: 384MB
  • Slots: 1 (1 bank of 1)
  • Standard Memory: 128MB non-removable
  • Open the bottom plate of the laptop and read the current information on the ram inside. this will tell you the type to buy....try http://www.pricewatch.com to buy it
    Oct 24, 2009 | Compaq Presario 700 470024-192 Notebook
    Trying to locate where to put a memory card
    Hello, was wondering if you meant memory card or memory chip. If it is a chip, it goes next to the other memory chip in the slot. Must be right memory or the motherboard may fry out.
    If it is a memory card, you must have SD-MS slot. If you do not have the slot, you can by one and hook it up to the pci slot.
    May 22, 2009 | Compaq Presario 5000 PC Desktop
    I can't find find the memory slot
    check in left and right side or back side u find 1 usb adapter for it.
    Apr 10, 2009 | Compaq Presario Notebook
    Location of memory slots
    Hi.There are a set of instructions that we need to follow for the upgrade process.You can increase the amount of RAM (random access memory) in the notebook with an optional memory module approved by Compaq.The notebook contains 2 memory slots, one of which is accessible for an optional memory module upgrade.Please refer to think link and select the Hardware Upgrade option in the list in the file which will guide you thru picturised views for helping in the memory upgrade.Link is : http://h10032.www1.hp.com/ctg/Manual/c00090108.pdf.
    Please let us know whether this help or whether you need more help
    Mar 16, 2009 | Compaq Presario R3000 Notebook
    Memory upgrade for presario 2100 notebook
    Hope this helps . Just follow this steps.
    1. Turn off your laptop and turn it on the reverse side. (under the keyboard see picture)c4c84c4.jpg
    2. Remove screws and cover .
    3. Remove the locks on both ends of your memory (encircled in yellow) . This is done by holding the locks on both sides using your thumbs.
    4. While holding the locks gently push the locks away form the memory (sideways)
    5. The memory will popout and you may now remove and replace it with a higher capacity.
    Note: This is only done if there are no available slots for the new memory. If a slot is still available no need to remove old memory. Just insert the memory on the available slot
    Jun 17, 2008 | Compaq Presario Notebook
    Reg ram upgradation
    Each memory slot on the C555NR can support a maximum of 1GB of RAM. There are actually 2 slots, but only one is easily accessible to you. By upgrading both the primary and secondary DIMMs, you could achieve a total of 2GB of memory but you would have to remove the 512mb chip that is already installed and replace it with 1GB (+1GB in the expansion slot as well.)
    If you don't plan on taking the computer to a professional to be serviced, you will probably only want to upgrade the memory in the secondary slot located under the memory cover on the underside of the computer. It can handle a 1GB SODIMM.
    FYI the memory is:
    200 Pin DDR2-533 PC2-4200 SODIMM
    Apr 21, 2008 | HP Presario C555nr Notebook
    Cant find power button
    here's a link to a page with a diagram of the buttons above the keyboard and will show you the power button.
    http://armbrust.dyndns.org/tips/presario700/700_systemviews.htm
    Dec 20, 2007 | Compaq Presario 700 470024-192 Notebook
    Compaq Presario 700 470024-192 Notebook Logo
    57 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
