Question about Denon AVR-1908
My received does not stay on for very long. i/e, I am in the middle of watching a movie or tv and the receiver will shut off by itself. is there a way to solve this problem?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 137 Answers
You have a power supply problem as one of the +15v or -15v Regulators are bad. This is easy replaced at your local denon service shop.
Posted on Apr 17, 2010
Why does my reciever keep turning off by itself?
try looking into the Timer section on the TV. also on Dish if it is left unattended (like stay on same channel etc) it will go in to sleep mode, U then just hit the Select button.. U can go in the Dish menu and set the Sleep mode (inactivate mode ) to a longer time, I usually set my for 8 hours.
Jul 09, 2014 | DISH Network DVR-625 DTV Receiver /...
Receiver shuts off when we are watching a movie, usually about 10 min after the movie starts...the receiver shuts off and the movie is still running?????????????
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Aug 09, 2011 | Denon AVR 3808Ci Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
When watching a movie, my receiver will shut off
The only thing you can do in this case is reduce the volume, or connect speakers requiring less power to run them.
Jun 15, 2009 | Audio Players & Recorders
The audio and video are not in sync
Are the movies you're watching store purchased DVDs? Sometimes with downloaded movies, the audio and video are just out of sync.
If they're store bought, it's possible that you've got a delay set in your receiver. Consult your receiver's operating manual to see if there's a "delay" option.
It's also possible that you're hearing that delay in the TV speakers.
If you've got the audio coming through the receiver AND the tv, you'll hear a slight delay when the audio's traveling from the DVD player to the television itself. This could happen "sometimes", if the tv volume is on, and not happen when the tv volume is off.
Mar 19, 2009 | Sanyo DVW-6100 DVD Player/VCR
TV IS NOT RECEIVING SIGNAL FROM LAPTOP
Check graphic card software on laptop to make sure it's on the right settings to output image to TV.
Nov 20, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Philips FTR 9964 Receiver Problem
The problem is in your cable connection on the back of your monitor or Box. I had the same problem and solved it by reattaching the VGA cable that was loose.
Nov 14, 2007 | Philips FTR-9964 Tuner/Receiver for Plasma
Denon AVR-1908 Logo
154 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
