Question about Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors
HOW TO RESET LOW OIL LEVEL SWITCH? - Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors
  • 98 Answers
If this is an I.R compressor the switch should reset itself once you add oil if it dont you may have a bad switch
Posted on Jul 21, 2009
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
If oil is low will it affect starting? is there a kill switch
Honda engines originally fitted the low oil level kill switch which some other manufacturers have copied so yes a low oil level could affect starting but only if your mower engine is fitted with a low oil level kill switch. Not all engines have the switch and in an ideal world the facility would not be needed...
Mar 15, 2015 | Garden
My Briggs 23hp ran out of fuel is there a reset switch as the engin will not start anymore.
I would be checking low oil level as there is a low level oil switch that switches off when you run low on engine oil.
May 10, 2013 | Briggs & Stratton Briggs Stratton Vanguard...
Honda es6500 low oil lamp on engine oil is at upper limt. reset butten did not pop. engtne will not run
If the low oil switch fails, you have to jump the switch for the engine to operate. I have a compressor with that problem. Then either you watch the oil level carefully or install a new switch, which, in my case, requires disassembly of the crankcase.
Gary
Aug 28, 2011 | Honda Electrical Supplies
Code P1259 what would cause this?
P1259 is the code for the VTEC pressure switch.
1. Check your oil level first, if oil level is low the code will come on. Add oil and reset the light.
2.you might have a bad Vtec oil pressure switch, try replacing it.
Jun 26, 2011 | 1998 Honda Accord
OHH55 engie has low oil cutout. Is that something that can be reset, and if so, how?
The low oil cutoff is an electronic switch inside the crankcase. If filling oil to the proper level doesn't allow the engine to run, the switch must be bypassed or replaced and to replace, the engine must be opened.
Gary
Apr 18, 2011 | Garden
How to reset oil light on dash of 01 1.4 golf
Oil lights do not reset.
Your Golf either has low oil level/pressure or the oil pressure sending unit/wiring is bad.
You need to immediately check your engine oil level. The instructions are in your manual.
If the oil level is low, DO NOT DRIVE THE CAR! YOU WILL DAMAGE THE ENGINE! Add oil as instructed in your manual and the light should go out within 20 seconds or so after you start your car. You will then need to check for leaks and/or find out why your oil was gone.
If the oil level is normal, you need to get the car to a mechanic to see if the problem is the sending unit or an actual oil pressure problem. Since at this point you cannot be certain, I recommend that you have the car towed to avoid engine damage that will happen if your oil pressure is indeed low.
Feb 10, 2011 | Volkswagen Golf Cars & Trucks
Yellow oil symbol kept turning on
this could be due to low oil. you need to check your oil level. if it is full i would do an oil change with a bmw filter. there is a difference in filters. the service engine soon light will have to be diagnosed. meaning pull codes to point you in the right direction. great car though. happy holidays
Dec 24, 2009 | 2000 BMW 3 Series
Oil light stays on although level is up.
Either low oil pressure, or a leaking switch. If your switch is not leaking, you most likely have an oil pump problem, or a worn out motor.
Jul 06, 2009 | 1987 Pontiac Grand Am
1994 Toyota Celica 1.8 liter
Oil sending switch,or loose wire going to this switch,this controls the low level oil light.
Jun 29, 2009 | 1994 Toyota Celica
Ingersoll Rand Air Compressor Maintenance Kit for TS7 Air Compressors Logo
606 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Eddie Tucker
Level 1 Expert
John Trevino
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
