Question about Linksys Wireless-G Range Expander (WRE54G)
No connect to router wireless, no wizard - Linksys Wireless-G Range Expander (WRE54G)
    Scholar:
  • 62 Answers
You have to make sure that the settings on your wireless router is exactly the same as your wireless expander. Before you place your wireless expander to the spot you want to extend your wireless network, you may want to test it first when it is 10ft to 15ft away from your wireless router. Just to make sure you got it working. And then just keep on moving your expander every 10ft until you reach the farther spot that the expander can reach with good connectivity.
Posted on Jul 02, 2009
Am using Windows 7. Just bought a Zhone 6218 Wireless Modem. I have connected it ok. I can access the internet but I cannot access my Wireless signal,
Good day!
if you wish to connect on the wireless connection..you need a software that install on the usb its called wireless usb..
just go to the wizard wireless connection..the wizard teach you how to connect it step by step after that insert the wireless usb to the usb port..
thanks for using fixya..
Jul 02, 2011 | Zhone (6218-I2-200) Router
How to change my password in wifi?
You can configure the router by running the Setup Wizard in the
CD-ROM provided in the package. The wizard provides quick setup
for the Internet connection, SSID, wireless security, firmware
upgrade and changing router's password. When you start the
Setup Wizard, you will get the following Welcome screen. Please
choose the language to start with and follow the easy steps in the
Wizard.
Manual Below:
http://www.edimax.co.uk/images/Image/manual/Wireless/BR-6226n/BR-622xN_Manual.pdf
May 10, 2011 | Edimax BR-6226n nLite Wireless Broadband...
How to instal
You'll wanna check out: ftp://downloads.netgear.com/files/WNR1000_SM_WW_23Jan09.pdf
Look for "installation"..
To help you set up your router and get on the Internet quickly, the Resource CD contains a Smart Wizard™ Installation Assistant. The Installation Assistant walks you through the steps required to connect your router, modem, and PC(s); configure your wireless settings; and enable wireless security for your network. When you have finished, you will be Internet ready!
You can set up your wireless router using one of two methods:
• Smart Wizard Setup: The Smart Wizard Installation Assistant setup is available on your Resource CD. See "Installing Your Router Using the Smart Wizard" on page 9 to use the Smart Wizard Installation Assistant.
- This is the easiest option. The wizard guides you through the setup process. It automates many of the steps and verifies that the steps have been successfully completed.
- Smart Wizard requires a PC running Microsoft Windows.
• Manual Setup: If you cannot or prefer not to use the Smart Wizard Installation Assistant, see "Manually Installing Your Router" on page 13. For example, if you are connecting to a Mac, are using a Linux operating system, or are technically knowledgeable, select this option. If you choose to use this option and install your router manually, for best results, install and set up your router in this order:
Failure to follow these guidelines can result in significant performance degradation or an inability to wirelessly connect to the Internet.
NETGEAR does not recommend or support adding a NETGEAR router behind another router, or replacing a gateway with a a NETGEAR router.
If you have a Macintosh or Linux system, you must use the manual installation method (see "Manually Installing Your Router" on page 13).Getting to Know Your Wireless Router 7
1. Install and connect your wireless router to your network (see "Connecting Your Wireless Router" on page 14).
2. Set up your wireless router for Internet access (see "Setting Up Your Router for Internet Access" on page 18).
3. Configure your wireless network and select wireless security settings to protect your wireless network (see "Configuring Your Wireless Network" on page 21)
Feb 04, 2011 | NetGear WNR1000 Router
Connected to d-link network which is unsecured. how to secure?
You need to setup a password for the wireless connection,
1. Connect D-link Router to your computer
Your computer should be connected to the LAN port of using an Ethernet cable.Power on the router after connecting the router to your computer.
2. Log on to D-link Wireless Router
To logon to wireless router type the default IP address of the router on the address bar. The default IP address of the D-Link router is 192.168.0.1
Before log on to the router it will ask you the user name and password. For a default D-link router
User Name : admin
Password :admin(Flip the router over to know the default username and password)
3. Click on Setup Wizard
To configure the router in an easy way click on the button Setup Wizard.
4. Click on Launch Internet Connection Setup Wizard
To configure the internet connection in this D-link router, click on the button Launch Internet Connection Setup Wizard.
holygrass_21.jpg Now the wizard will show you what steps it is going to complete while running the wizard. Click Next to continue.
holygrass_22.jpg 5. Create new Password For your router
holygrass_23.jpg Setup wizard will prompt you to create a new password for your WBR-2310 Wireless Router. After entering the password click on next.
6. Select your Time Zone
Now the setup wizard will prompt you to select your time zone.
holygrass_24.jpgPost .
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | D-Link Computers & Internet
How do i make my wireless router secure
Well you have to enter the router's address to configure the router.
Go to Network connections- right click on the Local Area Network icon- Status- Support- now look for the default gateway. That is the address of the router.
Insert that address (e.g. 192.168.1.1) and you will be asked for a username and password. Default it may be user: admin; password: admin; or blank spaces.
Now go to Wireless setup and chose Wireless Connection Setup Wizard. If you do not want the wizard you can always do it manually. Follow the steps provided by the wizard and you will have your connection secured in no time.
If you need further assistance or if you have further questions regarding this problem please leave a comment.
Cheers
Aug 25, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Good day to all. I have a problem of my NETGEARWPN824V3
To access the Smart Wizard installation and configuration program on your router:
  1. Connect your router to a computer by plugging one end of an Ethernet Cable into any of the four LAN ports on the back of your router.
  2. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
  3. To install your router, simply click on the "Setup Wizard" link at the top of the left-hand navigation menu once you are logged into your router.
Configuring Smart Wizard for WEP encryption:
  1. Click Start then go to All programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  2. NETGEAR Smart Wizard wireless utility should appear on your desktop screen.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless network within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit the Connect button.
  5. On the Settings tab, click WEP under the Security option then select Enter Key Manually.
    Note: If the network key consists of 10 characters, set it to 64 Bits. If the network key consists of 26 characters, set it to 128 Bits.
  6. Type the 10 or 26 characters (Hexa decimal) keys on the space provided.
  7. In the Profiles field, assign a name to help you remember this wireless network settings in the future, then click Save Profile.
  8. Click on Apply to validate the settings.
  9. Once connected wirelessly, go to About tab and check for an IP address.
Configuring Smart Wizard for WPA encryption:
  1. Click Start then go to All Programs. Look for NETGEAR wireless adapter folder then select the NETGEAR Smart Wizard.
  3. Click on the Networks Tab. This will automatically scan for all the available wireless networks within your proximity.
  4. Select the SSID of the wireless network that you want to connect, then hit Connect button.
  5. On the Settings tab, select WPA under the Security option.
  6. Type the WPA password/passphrase inside the empty field next to the WPA drop down menu.
Best of luck and have a happy and safe 4th of July weekend!
Jul 02, 2010 | NetGear RangeMax WPN824 Router
I lost my password and lost the WGT624 installation CD, how can i get the router to work on a new laptop
If you have lost the password to access the router page then you have to reset the router
Ensure that you have all the details regarding your internet connection before resetting the router
If you reset the router you can run the smart setup wizard and get connected by entering correct information in all the pages of the wizard
If you are looking for the wireless password:
Access your router page ( Open Internet Explorer --> Type 192.168.1.1 and enter it--> Login name(default)-admin, Password(default)-password) --> GO to wireless settings,under Wireless settings you will find the wireless password.
Jan 17, 2010 | NetGear WGT624 Wireless Router
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Cann't get my wireless router to work,don't understand how to config the router.
HI helock,
This is a step by step instructions:
Note: It is recommended that you configure the Wireless Router from a wired
computer.
1. Open your web browser, type http://192.168.10.1 in the Address bar, and then press Enter.
2. Enter the User Name and Password, and then click Log In. By default: User Name: admin Password: admin
3. The Wizard will automatically appear. Click Wizard if the Wizard does not automatically appear.
4. Click Next.
5. Select your Time Zone and then click Next.
6. Click Next. Note: Do not change default settings unless it is conflicting with your existing hardware.
7. The TEW-432BRP will attempt to auto detect your Internet connection. Follow the wizard instructions and continue on to step 9.
8. This screen will appear if the TEW-432BRP is unable to auto detect your Internet connection. Configure the settings based on information provided by your ISP.
9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection type may have different options.
10. Click Next
Note: It is recommended that you enable encryption on the wireless router. Please refer to the User Guide on the User's Guide CD-ROM for information on
setting up encryption on the wireless router. 11. Click Restart. 9. Follow the wizard instructions to complete the configuration. Note: Each Internet Connection
11. Click Restart
12. Click Close.
13. Wait 30 seconds while the router reboots.
14. Verify that the following panel lights are on: LAN, WAN and WLAN.
15. Open up your browser and enter in a URL (e.g. www.trendnet.com) to verify that you have Internet connection.
Your configuration is now complete.
Good Luck,
And don't forget to leave a rating
Thanks
Mark
Sep 14, 2009 | Trendware TRENDnet TEW-432BRP 54Mbps...
Linksys Wireless-G Range Expander (WRE54G) Logo
218 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
