Question about Microwave Ovens
Handle replacement on GE JVM 1860SD - Microwave Ovens
  • 5,911 Answers
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
Posted on Jul 01, 2009
What replaces model jvm 1630 wj microwave
JVM models should be a GE NOT A WJ
Feb 13, 2018 | Microwave Ovens
GE space maker microwave jvm1350bw002. Handle broke off at the bottom. I am looking to find a replacement hand determine if I can replace and if so are there instructions on removal of the handle?
On all of the JVM series I have seen you have to open the door and look on the inside perimeter of the door. There is a sort of thin, sort of Plastic, choke seal that goes around the inside of the whole door. Toward the outer edge. You have to take a butter knife or a smallish screw driver to lightly pop that part out of the slot it is popped into. The screws for the door handle are under that choke seal. Work around the whole door until you get that part out, Get one piece to lift up then keep working artound the whole door until it comes out. Then set it aside somewhere safe as to not let it drop or fall to the floor as it can break. To reinstall the choke you just align it to the slot where it came from and then start pushing it back into place. It has little hooks on the edges and it will snap back into place
Oct 15, 2017 | GE Microwave Ovens
Need manual
Hi
Thanks for using FixYa. Please see the link to download the manual for GE Space Maker JVM 1640SJ Microwave Oven---
GE JVM 1640SJ Microwave Oven Manual
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Profile Spacemaker XL Sensor Mod # JVM 1350AW 02 Microwave oven. How do I replace the door assembly? Is there a danger of elecrical shock involved?
You're usually better off just replacing the bad parts instead of the whole door.
If so, you can separate the door panels (as shown in the attached photo) then you can replace separate parts.
You can't remove the handle without doing this.
You can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 09, 2009 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a JVM 1650BB008 GE microwave oven. I am trying to replace the outer door frame and handle, which are broken. I have removed the door and have pried off the choke cover. Now I need to remove the old...
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
You have to remove the door handle screw(s) and the door handle, then look for subtle clips that may be holding the outer door screen in place.
Some models have two screws holding the door handle, but some have only one. In that case, remove the screw, then you either lift or rotate the handle to free it.
If you still need help, please write me at prototech@usa.net for the service manual link (no charge, no obligation).
Sep 27, 2009 | GE JVM1190SY/WY/AY/BY Microwave Oven
Need to dissemble microwave oven door GE model JVM 1631 BB 002 to remove spider.
Remove the inner strip around the door called the choke. If there are no screws visable it just snaps in place and does break if you are not very careful. This will give you access to the screws holding the outer frame piece and handle on. keep in mind, any repairs done to the door will necessitate a RFe leakage inspection. Boil some water on the front burners and cook the little guy and leave the door alone.
Eric
Jun 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How do you replace the handle on a ge Space Master Oven JVM 1490 BD 003
To replace MOST microwave oven door handles all you have to do is open the door and remove the inner plastic panel around the glass. This is accomplished by taking a small screwdriver and carefully inserting it along the perimeter to pop it loose (there are usually some grooves you can insert the screwdriver in).
NOTE: DO NOT pry against the glass. The glass is tempered and has an RF shield that protects the consumer from the microwaves being generated by the magnetron. Breaking it, requires a new door replacement.
With the panel removed, you will be able to access the screws that hold the handle in place. Once the new handle is in place, carefully reinsert the inner plastic panel by snapping it back in place all the way around the perimeter of the door glass.
If you have questions, or if your door is configured differently, please let me know. If you have the ability to send photos, that helps too. A model number may also be useful so I can identify how your door is assembled. I hope this helps you,
Apr 28, 2009 | Microwave Ovens
Microwave GE SpacemakerXL JVM 1450
If you need to ask how to do this task, you may have no idea of the extremely high voltages that exist under the cover, even when unplugged. I would advise a competent person changes it for you.
Aug 26, 2017 | Microwave Ovens
Microwave Ovens Logo
351 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
