Question about HP Computers & Internet
HP DV4000 Widescreen desktop image does not fill screen
HP DV4000 Widescreen. During power-on/boot and when XP is running, Windows desktop does not fill the screen. Leaves 3/8'' black area at bottom and 2-1/2'' black area on right side. Win Display Settings force 1024x768. Everything works OK except for the reduced screen image.
Have reloaded HP Driver CD; Intel screen driver; and run XP Repair.
OS is XP SP2. Graphics card is Mobile Intel 915GM/GMS/910GML
Maybe it's hardware?? Thanks for any help.
  • Venicejim Jul 02, 2009
    Thanks, Tenusha. As I stated in my original post "Win Display Settings force 1024x768."
    Doing this will change the screen image (creates distortion) but not increase the desktop image to cover the entire physical display area (WXGA, 1280x800)
    Problem Solver:
  • 7 Answers
Go on u deksto click with right-properties-display setings and change the resolution.
Posted on Jul 01, 2009
How do I rest a hppavilion dv4000
Either the computer came with a recovery disc, or during the boot up at the HP screen thre should be some options. Typically F11 will get you into a recovery partition which should allow you to re-install Windows. This will wipe out any data you have.
Jan 18, 2015 | HP Pavilion dv4000 Notebook
Why my hp desktop keep turning off error c000021a
this is how to fix your desk top with xp,if you have another os,this may also work,but,be prepared,you may need to reinstall your os,if this works,then immediately download this and run it, SpeedyPC Pro Download ,and then d/l this and buy it to keep your pc running great,http://www.iobit.com/advancedsystemcareper.html , Things You'll Need
  • Windows XP installation CD
Instructions
  1. Last Known Good Configuration
    • 1Restart your HP computer after the blue screen shuts it down.
    • 2 Repeatedly tap "F8" when the HP logo screen appears during bootup. This will load a menu with various boot options to select.
    • 3 Use the arrow keys to select "Last Known Good Configuration" and press "Enter." The system will roll back recent changes and may fix the problem. Continue to the next step if the computer does not successfully boot.
    In Place Upgrade
    • 4 Insert the Windows XP installation CD into your HP computer's disc drive.
    • 5 Restart the computer.
    • 6 Press any key on your keyboard when you see "Press any key to boot from CD..." This will launch the Windows Setup program.
    • 7 Press "Enter" to begin the installation process.
    • 8 Press "F8" to agree to the Windows XP licensing agreement.
    • 9 Highlight your current installation of Windows XP and press "R" to perform a repair installation.
    • 10 Follow the onscreen instructions to complete the repair installation. Your personal data and applications will remain intact, but all Windows updates and service packs will be removed during this process.
Tips & Warnings
  • Back up your data before running a repair installation on your HP computer.
Related Searches
eHow Now Ask online tech support online now Ask online tech support - get your answers in real time!
Get Your Answer
References
  • Photo Credit laptop with blue screen image by dim@dim from Fotolia.com
SpeedyPC Pro Download Advanced SystemCare Free 7 6 5 4 3 Download Review for Windows XP Vista...
May 21, 2014 | HP Computers & Internet
Hp pavilion dv4000 pc notebook cant install windows xp from usb there is a continues blink cursor on the top left corner
You need to make the USB first boot in BIOS, or use the boot menu selection. Both are noted during start up.
Then there is the issue of the USB install is it bootable? You need software like Novicorp to make an USB Installer. gl
Dec 12, 2012 | HP Pavilion dv4000 Notebook
Display does not fill screen completely
ok right click anywhere on the screen go to the bottom and click properties now there will be a couple of tabs at the tom desktop screen saver you want settings raise your resolution to about 1200 x800 or higher i think native for that is the 1680x1240 this should fix your problem
Nov 25, 2009 | Acer X203H bd Monitor
DV4000 display is in XGA mode does not fill the screen
Please check the unit with the external monitor>If the External monitor works fine >Its an issue with the LCD of the unit you can replace it
If the External monitor is also actining in the same way>It could be an issue with the system board.
After all the driver updates this is the finall step,
If not possibel to replace the LCD, try to reinstall the OS
Jul 03, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion DV4000 laptop screen only showing as 4:3 aspect ratio
Have you changed the resolution?
Go to control panel, display, settings, and make sure the resolution is set to more. Click on the advanced button and choose the tab for graphics or the graphics controller, choose properties, and adjust the screen area.
Please also consult this link recommended setting for HP notebooks. (click here)
If that doesn't do it, is there a possibility that the wrong driver has been installed. You can check the original product specs at hp.
Apr 16, 2009 | HP Pavilion dv4000 Notebook
Window will not boot up
IT DOESNT MATTER WHAT SEQUENCE IF BIOS CANT FIND 1ST DEVICE IT GOES TO NEXT AN SO ON,
TRY THIS.BOOT UP GET A FAR AS YOU CAN GET THEN PRESS AND HOLD THE POWER BUTTON(ABOUT 5 SECS)
THEN REBOOT.
IF THIS DOESNT WORK BUT YOU CAN GET TO THE WINDOWS SCREEN PRESS CTL+ALT+DEL AND CHOOSE LOG OFF THEN IN NEW SCREEN SELECT LOG ON.
IF THAT DONT WORK REINSTALL OS NOT REPAIR.
WHEN YOU GET TO THE INSTALL PAGE SYSTEM SAYS OS ALREADY INSTALLED CONTINUE TO INSTALL OR REPAIR .AT THAT STAGE EITHER CARRY ON AND INSTALL FRESH COPY OR REPAIR.
Jan 02, 2009 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 display dies b4 it even boots
When you get to the normal/safe mode screen, select enable VGA. This will boot your computer using the standard 640 x 480 default. Once you are in windows, then you can go into the display properties and change it to a resolution that is compatible with your screen and computer.
Thanks and pelase take a moment to rate as fixya.
Nov 08, 2008 | HP Pavilion dv4000 Notebook
My Hp Pavilion dv4000 screen stays blank
have you got a bootable cd or recovery cd , boot from it and do a fresh installation, i think your windows has got corrupt
Nov 05, 2008 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
191 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
