I have just purchase a Daewoo Lanos 2000 It cam with no books and I am not sure where to find all the component. Please any one that can help Lady in distress
SOURCE: User manual for daewoo lanos car
Need code to work radio. Replaced the battery and it is asking for a code for the radio to work
SOURCE: 2000 Daewoo Lanos intermittently idles rough
check throttle body and pcv hoses and ports for blockage possible carbon build up and sticky iac valve
SOURCE: 2000 Daewoo. Lanos won't start. What are the cam shaft positions
both lobes on number 4 cylinder face each other (point towards centre of engine)when timming marks on cam gears are lined up
SOURCE: Daewoo Lanos 1.4 1997 Idling really high - Idle Rev Valve?
hi there the problem describe is a common problem you need to take the car into your dawoo/chevrolet dealer as there was a reprogramme that need s to be downloaded to your ecu to fix the problem should only take about 30 mins so should not cost you to much i used to have around 10 to 15 a week to do
SOURCE: How to replace front wheel bearings on 2000 Daewoo Lanos
they come as a whole assembly hub and all
