The instructions for the fuse box are in Japanese and I can't tell which one is for the indicators.
Do you have a test light? If you do, ground it and probe all fuses with the key in ON, not start, and with the indicator turned to one side or the other. The fuse that blinks the test light is the indicator fuse. All the other fuses will have a steady light on the tester. With key on, all fuses should have power to and through them.
The tops of all fuses have two slots on the top-one at each end. these are test ports and open to the metal strip inside the fuse. Touch the needle probe of a test light into one of the slots. With key on, it should light up the tester. A good fuse will light the tester at both ends, both slots of the fuse. But a blown fuse will light up a tester at only one end of the fuse-the power into the fuse, but no power on the other end of the fuse- the metal strip has blown apart and the fuse will not pass power. You can check any fuse this way, without pulling the fuse out to investigate.
SOURCE: Toyota lucida fuse box is in Japanese
Usually this will be a 15 amp fuse, and usually blue. This should narrow it down. Pull one out, see if its blown. If you can't tell, put a new one in, and move the old one down to the next blue one. Eventually, you will figure it out. Then I would get an owners manual in english, or buy a dash cover at junkyard, so you will have it for future information. A dealer should be able to print, and give to you a fusebox diagram, then you can glue it to the inside of the fuse box cover. There are also some master fuses under the hood, 30 amp and above.
SOURCE: Is there any way to change the sat nav language
It's not possible. You could try these guys though http://www.carkit.co.nz. They can install a NZ gps that will use the in built screen, they can set it up for ipod integration into the screen too. No idea on price thought I'm waiting for a quote, big dollars I suspect!
SOURCE: we have a 2002 nissan
nissans have multi fuse boxes make sure you check them all under hood drvs and passenger kick panel also under back seat,the dash and tail are on most cars in the same circuits
SOURCE: How often should I change
A fuel filter is usual maintenance...........Ir should be good for 60,000 depending on how much gas line antifreeze you use due to certain additives which will break down the internal make up of the filter itself.....Hope this helps.
