Question about Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft.
What will cause door heaters to trip breaker.
When door heaters are plug up breaker trips ohmed plug with power off no ground plug in trips breaker whats wrong
Victoryfreezer
M# VF-2.
    Sergeant:
  • 340 Answers
You have a short some place isolate each component if you disconnect the heater and it does not trip the the breaker replace heater. caseparts.com good luck Tom
Posted on Jul 03, 2009
15 AMP breaker keeps tripping
do a amp check on the compressor and fans.That will tell you exactly what is overloading.
Apr 21, 2012 | Kenmore Freezers
We have the Delfield XL 6000 freezer. We have been having problems with the breaker keep fliping off and causing to loose food. We have had Delfield technicians to come out on several occasion and they...
Ok ,
Does it trip all the time now,or only after running a while.?
If it trips right when you reset breaker with machine OFF, have the wiring checked for a dead short to ground up to the thermostat.
If it trips after running ,as it starts or intermittently there's a dead short to ground that could be any where.
You can simulate what is going on by doing this check.
Unplug machine.
Using an ohm meter,set to ohms, place a test lead on the ground prong(round one) .Place the other test lead to one of the remaining prongs.If there is any reading youv'e got a short. Try the other prong as well
However, if you get no reading there still could be an intermittent short .
Another thing to check. It might not be the machine at all.
Sometimes,if your wall recepticle is worn or old it can heat up causing circuit breaker trip.
Make sure there are no extention cords involved.
If you're on a 15 amp circuit ,you might want to upgrade to 20
Good hunting
Aug 18, 2011 | Delfield Freezers
Freezer keeps tripping breaker
Possible that it is draining a larger current and so it trips the breaker. Check if the capacitor to the motor is faulty, replace if you find it on test to consume more current and low charge.
Also the motor can be checked , the wiring to the freezer specially the GROUND connection as any leak can also trip the circuit.
Jul 18, 2011 | Silver King 1242.90 Front Breathing...
Is it possible for a delfield freezer 6151 XL-S to trip a breaker every 2-3 hours if the TXV valve was faulty letting liquid get to compressor. This unit has had controller and relay start assembly...
I would look to see if it is tripping during the defrost cycle. One of the heater elements my be faulty. Never heard of a bad TXV causing a breaker tripping, but I guess it's possible. I would adjust the superheat so that it is about 6 to 8 degrees just prior to unit reaching temp and shutting off. I'd start there.
Apr 01, 2011 | Delfield Freezer 6151XLSR Stainless steel
My Whirlpool Intergrated Freezer AFB 823/3 trip The Earth Leakage CB on the house Fuse board!!
This one requires more information. If the breaker trips randomly, then I say there is grounding problem between the plug and the freezer itself. I know the UK has a very large plug and it requires a serious connection into the wall. I would check and make sure you have a good ground on the box itself. You may have to removed the back and look at the connections If you have a V-OHM meter you can verify the ground through different parts of the freezer. If this never happen before and you just bought this freezer I would replace the breaker with a new one. The breaker maybe damaged and sensitive to heat from the current draw of the freezer. Also make sure it is the correct ampere required to run the freezer.
Feb 20, 2011 | Whirlpool Freezers
After moving to a new home, the freezer keeps tripping the breaker every few days
My first instinct is to ask you, are you plugging this freezer into a GFI outlet, one which has a breaker switch as part of the outlet? If so, that is the culprit and not the freezer, as refrigerators and freezers will often trip this ground fault indicator because water can on occasion reach ground, which causes the breaker to trip on the outlet.
Test this by plugging the freezer into a non GFI outlet for longer than a few days. Nothing is broken and you dont need refrigerator repair service.
Sep 29, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Actually, its a True T-72 refrigerator. After running for a few weeks, the unit trips the breaker and continues to do it unless I leave it off for a few days and then re-plug it in, at which point it runs...
some manufacturers use a heater in a pan for the condensate water that is generated from the defrost cycle. It is usually located near the evap and compressor area. I've even seen them under the condenser coil. Look for a heated pan. You may have a bad heater. When it goes into defrost, water enters the pan and trips the breaker as the heater may be open and water enters it shorting it to ground. Waiting a few day allows the water to evaporate out. And the process starts all over again.
I would look for this first. If this does not pan out, let me know and we can dig alittle deeper. But try to have more details.
Dec 29, 2009 | True 72 cu. ft. / 2039 liter Commercial...
True Freezer- The 5 amp circuit breaker trips when the light on
I believe that breaker is actually for door frame heaters. Most true freezers have a resettable breaker for the door perimeter heaters only.
Sep 11, 2009 | True 23 cu. ft. / 651 liter Commercial...
Trips breaker when door opens
Sounds like the switch or wiring around the switch is shorting out. Most light switches pop out with a screw driver.Some older units might have a small heater in the door around the seal but usually not See if there is any wiring going through the hinge pin. If so you can safely cut and tape this off. The door might sweat a little but this is a solution. Please deal with this as it could be a shock hazard. You might not notice if you touch and are wearing dry shoes, but a barefoot child could be killed.
Jun 27, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Victory Freezer Freezer, Reach-In, 2 Door, 45 cu. ft. Logo
150 people viewed this question
Top Victory Freezers Experts
Dennis Boxerman
christian nielsen
David Emmel
David Emmel
Are you a Victory Freezer Expert? Answer questions, earn points and help others
