Question about Maytag Dryers
Will not turn on was working then would not turn on again
  • Maytag Master
  • 19,396 Answers
Check that the door latch is closing properly, the door latch contacts can be tested using a multimeter.
Try cutting power for five minutes, this will reset timer board.
Check the lint filter, and eventually replace it.
Check and eventually replace the thermal fuse, on fromt load this is located at the back of the machine. Refer to owners manual for maintainance.
Regards.
Posted on Jul 01, 2009
Will not start
Have you tried turning ON PC, turn it over and remove battery. Turn PC over again and turn on. Turn over again and put battery back in. Turn on again and see if it works.
Dec 01, 2012 | Computers & Internet
Hi, I have Samsung freeze model No SRL551DP >both freeze and freezer. is not working.both has light, it flashes. If I turn main switches on and off it works again for four hours freeze and...
check the evaporator how much frost build up. if it build up block air way. the heat element or defrost thermostat is bad . otherway check the condensor make sure clean
Jan 10, 2011 | Refrigerators
My m1093 kodak camera won't turn on, it turns on briefly and then turns right back off again. i have tried charging it but nothing works
try taking out the battery and memory card, then put back in the battery, and try turning on again
then if that works put in the memory card and turn on
or try connecting to ur computer and transferring the pictures and then disconnect and try turning on again
Aug 04, 2010 | Kodak EasyShare M1093 IS Digital Camera
Dehumidifier doesn't draw in water (humidity).
It may be too cool in the basement for it to work. Mine doesn't work if its 67 or below. Take it upstairs and see if it works there, where it is warmer.
Apr 06, 2010 | Frigidaire FDF50S Dehumidifier
Turns on but just has black screen.power is on all cords checked.
levet cool down and remouve the hdd and power on
after that reinstal the hdd it shuld work again
Feb 12, 2010 | Sony Playstation 3 (PS3) Console
Gateway Laptop W340UA black screen
  1. take out the memory
  2. turn on again without memory (you should hear long beep sound) and turn it off again
  3. clean memory using eraser (better if you have spare memory to replace it)
  4. now try again
  5. if not working, checks whether the work properly? and clean the fan from dust. and try to switch it on again.
I look forward to hearing further.
Dec 14, 2009 | Gateway Computers & Internet
Beko 32" TV won't turn on.
i have universal remote, how can i turn on dvd on beko
Feb 09, 2009 | Beko 324250WN 28" TV
"turn off and on again"
a few weeks ago i dropped my camera in the sea and i thought, ****. i was in the same boat, so i opened the shutter myself and turned on the camera and it works and takes pictures but the shutter wont close again so if you can make sure you have no dirt in your lense and you can manually open the shutter yourself it may work and if it stops turning on all together keep charging it and once it goes green turn the switch off and on again until it always turns green then it should work again.
Jun 22, 2008 | Samsung NV3 Digital Camera
Dryers Logo
49 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
