Question about Ricoh Aficio 1515 Black and White Copier
I need a manual for a rich aficio 1515 mf cannot figure how to change photoconductor
    Scholar:
  • 175 Answers
The PCU is removed by opening front door and right side door.Black PCU will have one electrical connector on front, very visible, that needs to be unplugged with machine turned off, push a little black plastic guide on left side of PCU and it should pull forward and come all the way out. Putting the new one in is reversed, except there will be a plastic strip that has to be pulled off before installation. Good luck, please rate this. Thanks
Posted on Jul 02, 2009
Displaying replace photo conductor corectly
If it is really saying this could be three things. Plug for photoconductor is unplug . This locate below toner hopper. Slide toner hopper out look under neath it is a blue connector turn off copier unplugged it and replug in turn on or bad photoconductor or bad board. If it's saying replace it then you have reach end of life for it will need to replace.
Jan 18, 2014 | Ricoh Aficio 1515 All-In-One Laser Printer
I have several of these ricoh 1515 copiers all working fine and then posting a need photocunductor error. Is this some preset error that comes after so many copies like HP got sued for or is the...
Hi, the "Replace Photoconductor" message does come up after a preset number of copies, typically about 60,000. The photoconductor will still continue to work fine, and even with the message displayed the copier should run like normal. The message will keep flashing until you replace the photoconductor, and then it will automatically detect the new unit and the message will disappear.
Jan 21, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
Support manual aficio 1515
You are able to search an on-line database; enter Black & White Multifunction for the product; select Aficio 1515/F/MF/PS from the pop-up list. Searh according to your information needs:
http://www.ricoh-support.com/enduser/support/supporturl.asp?url=https://eu-ricoh-en.custhelp.com
I was not able to locate a manual however you might want to check to see if you have the most current driver for your printer and operating system. See here:
http://www.ricoh-support.com/enduser/downloads/downloads.asp?fileid=14359&ricohmodelid=6225&url=http%3A%2F%2Fsupport%2Ericoh%2Ecom%2Fbb%2Fhtml%2Fdr%5Fut%5Fe%2Fre%2Fmodel%2Fx15%5F15f%2Fx15%5F15fen%2Ehtm
Trust this is helpful.
Dec 27, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
My Ricoh aficio 1515 printing and copying with background
If background is appearing on your copies, the problem is most likely the photoconductor unit (PCU) which houses both the drum and the developer. It comes as one piece, and you can easily remove the old one and slide the new one in.
The PCU is located to the right of the toner bottle, and the new PCU will come with instructions for replacement, but it is a simple procedure.
If you don't have a local dealer or supplier, you can purchase a PCU online just about anywhere that sells copier toner.
Aug 30, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
WHAT RICOH PRINTER IS COMPATABLE TO THE RICOH AFRICIO 1515
The 1515 is compatible to the 161 and the 171, the two newer generations of similar printers. All three use the same toner and photoconductor units, and are set up almost identically.
Nov 20, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
We have message to Replace Photocondutor. Is that toner? If not, s it self-install or do we call for Tech?
Most photoconductor assemblies are what they call "CRUs". That means that they are Customer Replaceable Units.
Check with the Ricoh web site "Support" to verify the installation process and order the part.
Don
Nov 19, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I have a Ricoh Aficio 1515 MF. I cannot get my Windows XP Pro to recognize the scanner, and I downloaded the Twain driver from the Ricoh site. Help! I want to scan into Adobe Acrobat.
Does the machine show up on your computer - you can print?
do you see it in scanners and cameras in start - control panel -> scanners and cameras? what is the status shown there on the properties?
Jul 30, 2009 | Ricoh Aficio 1515 All-In-One Laser Printer
Printer Ricoh Aficio 1515
delete drivers and reload, make sure you're using PCL 5 drivers.
Aug 14, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh aficio 1515 all-in-one: problem with scanner
get your manual owner, and do the following instruction there
May 03, 2007 | Ricoh Aficio 1515 All-In-One Laser Printer
Ricoh Aficio 1515 Black and White Copier Logo
353 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
