sounds like a bad motor. when it hums when you push start, open the door. put a piece of tape on the door switch to hold it in. at the same time, push the start button and turn the tub with your other hand. if it starts, this only confirms it is a bad motor. the motor will need replaced. good luck. shane
My son put in a small load of clothes to wash it filled the washer and then nothing. I have tried...
(More)
My son put in a small load of clothes to wash it filled the washer and then nothing. I have tried changing it to spin cyle or rinse cycle and the machine is still not doing anything. It will not even reset the water level. It is like there is not power going to the machine.
The dryer did not heat the last load of clothes. The next time we attempted to start it and it made...
(More)
The dryer did not heat the last load of clothes. The next time we attempted to start it and it made a 1/2 second attempt by moving the drum about 4 of the 360 degrees and then stops. It basically makes the same sound in normally makes the second it's turned on but then immediately stops. I removed the front panel and the belts to both the blower and the drum look fine. Nothing else seems unusual. I don't know if theres an overheat fuse or switch but it seems if that was it then it would not even get any power. I don't want to remove the back/side panel because I'll have to take off about 25 screws and would rather not if I don't really need to. I have a multimeter if I need to do some troubleshooting but wouldn't know where to start. Please help!
hi my dryer won't run at all . nothing happens when you push the buttons and all 8's show up and it...
(More)
hi my dryer won't run at all . nothing happens when you push the buttons and all 8's show up and it won't reset
My tumble dryer (Service) started squeaking recently, Now it has started beeping. It has never...
(More)
My tumble dryer (Service) started squeaking recently, Now it has started beeping. It has never beeped in all the years I have had it. Is there a problem?
