Question about ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor
Black screen The monitor looks fine but when I turn on the computer there a black screen cover most of the part except for the START. I already try adjusted the horizontal, vertical, pincushion, pin balance, trapezoid, and parallel and the black screen does not go away.
  • dark010 Nov 09, 2007
    I swicth the monitor and there is no black screen so I know is the monitor but how do I fix so the monitor don't have the black screen.
  • 155 Answers
The problem could be in the Monitor, Computer or Cable. Did you try to connect another monitor or can you try to connect another computer (maybe a laptop) to that monitor?
It's important to understand where to start.
Posted on Nov 09, 2007
Six years excellent service then the screen went black except during start-up the start-up screen flashed om and off, and remained black through the Windows start. The screen did flash on for a second on...
You may have failed backlight inverter circuits, caps failure in the power supply, or bad lamps. Here is the service manual:
You will need to open it up and take some voltage measurement in the power supply first to make that you do have correct DC voltage feeding the inverter PCBA.
Mar 25, 2010 | Sony SDM-HS73P 17" LCD Monitor
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Black screen at start up?
IT SOUNDS THAT YOU HAVE A COLD SOLDER !! open the unit and check out the printed board and look around the transformer for a burnt or cold solder , re solder it and youre good to go , let me know , AJ
May 05, 2009 | Gateway FPD 1730 17" Flat Panel LCD...
Video problem on my Dell Dimension 4600 PC, HELP ASAP.
the resolution set by default when you load your graphics driver is outside the range of your monitors capability.
try starting in safe mode then adjust your resolution to 640 by 480 then restart.
if this works, adjust upwards to 1024 by 768
then up again till the screen blanks.
when it does, dont panic, wait 20 seconds and the settings will restore - you then have the optimum settings for your monitor.
good luck
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor flashes on when I turn computer on, then screen black
Your monitor power supply or inverter board have gone bad. Its not your computer video card
Apr 17, 2008 | Westinghouse LCM-19v1 Monitor
No picture on the screen
I have this Panasonic PanaSync SL70 17'' monitor, I don't use it often. It is still in very great shape. However, I tried to turn it on yesterday, I got a black screen. The power LED is on and I can hear the relay is clicking when signal received. I tried to remove the signal cable, I can see it turns to power saving mode. It seems that everything works fine except no picture. I am if the transformer is gone, but not sure. I am wondering if you can help?
Feb 19, 2008 | Panasonic PanaSync SL70 (White) 17" CRT...
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
My Screen Is Black When I turn the Laptop On
When you say ?it turns on fine? I?m assuming that the power and hard drive LEDs turn on. If that is the case it could be your LCD backlight giving you problems. With the computer on and the monitor power LED green shine a flashlight in the lower left hand corner of your screen. Look for the ?Start? button, if your backlight is not working you?ll see a faint ?start? button if you look closely. This is usually an economically repairable problem but not for the typical home user. Let us know if you have any other questions and please don?t forget to rate this posting.
Jul 30, 2007 | IBM ThinkPad T23 Notebook
ViewSonic E70fb (Black) 17 in.CRT Conventional Monitor Logo
137 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
