Randell 20072SC R-134a Refrigerator Logo
Posted on Jul 01, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A/C i have a 1996 cadillac car is it ok to put 134a freon in it
Charles T Nevin
Level 3:
  • Master 4,070 Answers
  • Posted on Jul 01, 2009
Charles T Nevin
Master
Level 3:
Answers
4070
Questions
0
Helped
1087325
Points
13055
Yes, that model has the 134. It should also have a sticker on the a/c telling what kind is in it.
I have 1991 Cadillac Fleetwood and need to remove ac compresser
If the compressor locked up the chances there are metallic parts in the rest of the system are great. Flushing out the system is best left to professionals. If your system has not been converted from R 12 freon to R-134a freon, now's the time to do it. The oil in the R-12 system is not compatible with r-134a. If there is still freon in the system you cannot simply discharge it into the air.. The fine is huge. Have an AC shop do the work.
I have a 1996 grand marquis that the air does not work in it.put can of frean in it
If in fact it does take Freon, it can be an expensive recharge because this nation requires an ASE Certification to even tough Freon. Yes, that is federal law in all 50 states. You can find out by finding an auto manual on your car to determine whether it takes 134A Refridgerant or Freon. Good luck...:)
Trying to recharge the a/c on my '92 deville...the new can doesn't seem to want to fit on the a/c under the hood...it is R-134a..Any suggestions or did we just get a defunct can???
PLEASE...PLEASE...PLEASE !!! Ensure you are connecting the can of freon to the correct, low side / suction, port...otherwise that can may explode.
You may want to also look at the decal under the hood somewhere that tells you the kind of freon that is serviced...and make sure it is R-134A...and not R-12.
Hope this helps...
"Low Freon" alarm on my 1996 ETC. When station
You have to disconnect the battery in order for the compressor to come on so it will take in freon. The compressor is controlled by the computer so disconnect the battery to reset the computer than try putting in freon. hope this helps leave comment.
1helpful
I need to know what kind of freon to put in my A\C
r134a is the replacement to all other a/c gas.so fully charge with 134.
Air con blows warm air
A couple of things will cause this problem. The first is making sure the compressor has voltage (blown fuse). The most common is it is low on refrigerant. Freon 134a. Good Luck.
Where to put freon in 1996 crown victoria
Requires R-134a refrigerant. Look for the black cylinder located on the passenger side under the hood. If you are unsure of how to proceed with recharging the system, consult with a certified technician.
Recently added a leak stop r-134a freon to my 1996 deville and after about 2 days the compressor wont turn on and it wont go to "auto" cool and stays on "econ" cool. after adding freon to car i noticed it...
If it's misting, this is a definite indication of an overfill. You should get a hose with pressure guage on it to avoid this. In the meantime, if a dangerous condition exists within your compressor. The optimal amount of pressure you're looking for is in the 40-45 psi range. Definitely needs attention or you will do damage to the system. Best of luck.
Greg
1helpful
2answers
Compressor is not staying on
39 0Z R12 (If it has not been retrofitted to 134A)
And 8 0Z of A/C Mineral oil
Please take time to rate this fixya
What kind of freon
R 134A is now the choice for freon use in autos. The "old stuff" R 12 has been banned for some time now. You car is new enough to have R 134A in it You should not have any problems in finding someone to check and recharge if nessary. Hope this helps. Moe
Top Randell Refrigerators Experts
ZJ Limited
ZJ Limited
john h
Are you a Randell Refrigerator Expert? Answer questions, earn points and help others
