Question about Bose Wave Radio
Bose radio remote
My bose radio remote control isn't working. I tried replacing the batteries, but that's not the problem. The clock comes on when i plug it in, but the remote doesn't work. Any suggestions?
SOURCE: bose clock radio Awrc-1p
Call the US tech support line, they will talk you through it.
Posted on Sep 26, 2007
SOURCE: bose radio won't turn on
check Q4 for short and replace
Posted on May 04, 2008
My Bose wave radio (w/cd ) was purchased in 1999, it was working fine untill it quit. Power is gone. What could be the cause and how could i fix it or can it still be fixed?
Posted on Nov 08, 2008
  • 483 Answers
SOURCE: Bose Wave Radio - Need IR Codes for cable remote
Check this manual,
this will guide you through the setup again :
Posted on Mar 25, 2009
SOURCE: Bose radio display doesn't show at all
I just posted a similar problem and did 2 more minutes of research on this site to figure it out. Hold down the 'cd mode' and press the on/off button. This turns the display on or off.
Posted on Apr 28, 2009
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
0 characters
1 Points
Is there a code for remote control universal rf 10
If you have a universal remote, you can try its code search feature to find a code for the Bose radio. However, Bose may use unique codes for its products.
Dec 09, 2014 | Bose Wave Radio
No sound Bose wave
I took mine back to the Bose store and they gave me credit on my Wave that was about ten years old toward a new CD wave radio. I would recommend taking it to the Bose store and see what they can do for you.
Sep 11, 2014 | Bose Wave Radio
Bose radio/cd controls not working
Try unplugging the power cord for 10 seconds and plugging it back in. This will reset the radio. Also make sure the batter in your remote control hasn't died on you.
Jul 11, 2014 | Bose Wave Radio
Remote quit working. Even replaced the batterys.
Try this advice:
"Dead" Remotes Can Be Saved
How to Re-Start Your "Dead" Remote Control
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck!
Jan 22, 2011 | Bose Wave Radio
The remote won't turn on the system at all. i replaced the battery with 2 new batteries and no change
If the problem is related for sure in the remote control then find some tips related to remote control problems. make sure there is no IR emission fromt he remote to confirm the fault of the remote.
Check this link below:
Remote control
Nov 08, 2010 | Bose Wave Radio
Doesn't work with remote
Jul 20, 2009 | Bose Wave Radio
Unable to connect ipod
Reset the radio (it has a processor) by just unplugging the power cord for about 30+ seconds and plugging it back in. If this doesn't solve the problem, try replacing the remote battery (CR2032- can be found almost everywhere batteries are sold) If all else fails, call Bose tech support. The cable you connected has nothing to do with this.
May 09, 2009 | Bose Wave Radio II
I changed the battery in my remote, and it works fine.
Oct 22, 2008 | Bose Wave Radio
Bose wave music system
Check remote and replace its batteries.
Does this remote work on any other device?
Sep 16, 2008 | Bose Wave Radio
Remote control problem
Replacement remotes for my AWR1 were $10 from Bose. Order online; receive by mail. I just bought two.
Jun 01, 2008 | Bose Wave Radio
Bose Wave Radio Logo
165 people viewed this question
Top Bose Clock Radios Experts
Sheila Brown
Level 1 Expert
Are you a Bose Clock Radio Expert? Answer questions, earn points and help others
