Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker is making a very loud noise when dispensing ice?
SOURCE:
BIKER T
  • 909 Answers
SOURCE: Clicking noise
THE FRONT PANEL IS DEFECTIVE. HAVE REPLACED TWO IN LAST MONTH. JUST TAKE NOTE OF MODEL WITH DEALER AS CERTAIN MODELS HAVE TO HAVE THE POWER BOARD REPLACED AS WELL.
Posted on Jul 20, 2007
Buffalo12980
  • 625 Answers
SOURCE: Water dispenser
the slide switch ice - water may not be making up. the paddle inside the door operates a common microswitch to either dispense ice or operates the water solenoid. check out the selector switch.
Posted on Aug 22, 2007
SOURCE: ice maker wont make ice
It is quite possible that the water line which feeds the ice maker is frozen. Whirlpool manufactures a "REPLACEMENT" water line that solves this problem. Fortunatly our problem occured while the refrigerator was still under warranty. I would suggest that anyone owning a Whirlpool product purchase the longest extended warranty available! They USED to manufacture a quality product. But I guess they just don't care about the consumer any longer. It is all about money!!
Posted on Dec 20, 2007
  • 1122 Answers
SOURCE: Ice make problem
I THINK WHAT YOUR SAYING IS YOU HAVE ICE AND WATER IN THE DOOR AND YOUR GETTING WATER IN THE DOOR AND NO ICE,IF THE ICE TUBE IS CLEAR YOUR PROBLEM LIES IN THE INLET WATER VALVE OR THE ICE MAKER ITSELF,YOU CAN JUMP THE WATER VALVE TO SEE IF IT SHOOTS WATER TO THE ICEMAKER,FIRST PULL FRIG. OUT,REMOVE BACK PANEL,TAKE TWO LEADS OFF THE VALVE NOW GO SEE IF YOU HAVE WATER STILL COMING OUT OF THE DOOR,IF YOU DO THESE ARE THE LEADS YOU NEED,FIND A OLD POWER CORD YOU NEED TWO CLAMP FITINGS OR GATOR CLIPS,SLIP THEM ON THE TWO TERMINALS ON THE WATER VALVE ,THEN PLUG THE CORD INTO A OUTLET AND COUNT TO 5 AND UNPLUG,NOW GO TO THE ICEMAKER AND PUT YOUR HAND IN THE WELL AND SEE IF YOU FEEL WATER IF NOT YOUR VALVE IS BAD,IF THERE IS WATER IN THE WELL YOUR ICEMAKER IS BAD,GET THE MODEL NUMBER FROM INSIDE THE FRIG. AND CALL LOCAL APPLIANCES PARTS STORE AND GET THE NEW PART,LET ME KNOW-MIKE
Posted on Jun 26, 2008
SOURCE: ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
Posted on Mar 26, 2009
I have a ge adora fridge that when pressing the lever for ice makes a loud humming noise & feels like freezer wants to explode. Cab anyone tell me if they have ever run into this issue
You probably have a ice dam in your ice tray. The anger is trying to dispense if but if the cubes have frozen together and produced a large chunk of ice it cannot break up. Open the freezer door completely and lift up and pull out through ice tray. Remove ice until dam removed. Reassert tray and make sure to turn ice maker back on. It is essy to inadvertently bump switch. Try dispensing ice to see. If noise went away.
Hope this helped!
Apr 19, 2016 | GE Refrigerators
Amana French Door Bottom Freezer Refrigerator making noise but not making ice
hello sir
if ur ice maker
Makes no ice
Jul 08, 2008 | Amana AFD2535DES French Door Refrigerator
Why is icemaker making a clicking sound?
Ice Maker Not Dispensing Ice ' ThriftyFun
www.thriftyfun.com/Ice-Maker-Not-Dispensing-Ice-4.html
Sometimes your refrigerator ice maker makes ice, but does not dispense it. ... If it gets pushed all the way back to the ice maker it prevents the metal arm from full ... Itry not to put anything on the shelf over the bin and also try to keep it pulled out just a little ... My ice maker is making a clicking noise and not making much ice.
Ice maker making ice, but won't come out thru door
www.appliance-repair-it.com/ice-maker-making-ice-but-wont-come-out-...
If when you attempt to dispense ice (and it doesn't work) the whole refrigerator seems to .... Many have just bought a new refridgerator or don't use the ice dispenser. ... I'vetried to decrease the cold in it from the dial and that doesn't help. ... The motor was working and the auger would turn with no ice in bin but the added ...
Dec 25, 2015 | Samsung RH29H9000SR RH29H9000SR 29 cu. ft....
We have a Samsung side by side refrigerator that we bought 1/22/2013. The ice maker is working but has begun making a very loud chattering noise. It is producing ice, the dispenser is fine, the only...
Turn ice maker off for 12 hr's. Next time you buy a ref. pay the extra $150 for a 5 yr. warrenty. Ice makers break all the time. All of them!
May 21, 2014 | Samsung Refrigerators
Amana AFD2535FES makes loud buzzing noise
When a start relay and the coil that opens the water for the ice maker or the water dispenser begin to weaken they some times buzz. Its possible you will need to either replace the=> 67003753 Water Inlet Valve
or the compressor=> 67005560 Relay or overload with run capacitor
Here is a parts manual for your=> AFD2535FES and a user manual=> HERE If you have questions please ask thanks Sea Breeze
Oct 18, 2012 | Amana AFD2535FES Stainless Steel Bottom...
Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Water dispenser and ice maker
you got it replace the water inlet valve but make sure it is bad first ...................The loud noise you hear maybe caused from too much pressure on the valve turn the pressure down a little and try again
Jan 10, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
174 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
