Question about Philips 32PT71B 32" TV
OUr television was working fine, until we simply could not get any power when we would turn on the power button. There is no response.
  • 767 Answers
Its a fuse :>
or power supply :<
To find out
unplug it for 30min
now when you plug it back in
you should see and hear a spark
this is normal and means it's
not a fuse. shop price about 95.00
Posted on Jul 01, 2009
Rca 42pa30rq
Hi! Hope this will give hint... I understand some televisions nowadays are fully controlled using remote but there is always a standby power button for the television remote function. If the there is no power after turning on using the standby power button please check power cables, supplies and fuses. If the television has a standby power waiting the remote to act on but no response after pushing the remote's power button check the battery and its contact. Goodluck.
Mar 18, 2014 | Televison & Video
Coby tftv2224 hard to turn on takes several tries
Sounds like bad power supply capacitors, simply fix if you have electronics repair skills.
May 20, 2012 | Coby TFTV2224 22 in. LCD TV
It was fine until we moved it. Not hard bumps simply moved it to another apartment now when we push the power button no power.
That model was famous for solder issue, Chances are the Flyback transformer may need to be resoldered. I would check the wire plugs and solder on the deflection board( Lower Left side when looking in the rear of the set)
Jul 19, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cannot program Dish IR remote l03602
adeline_roll
You didn't specify if you are trying to program the remote to your TV or receiver. Is it a replacement remote or did it just quit working? I have provided instructions on how to program to your TV or receiver.
Address to receiver:
Remote: All Other Remotes
  1. Go to System Info screen (depending on receiver - press System Info button on receiver panel or pull smart card out till System Info screen appears on TV screen).
  2. Hold down the SAT button until all mode lights light up.
  3. Enter a number between 1 and 15 using the numeric keypad on the remote.
  4. Press the pound (#) button.
  5. Once the SAT button blinks three times, press record. Note: If successful, the number selected in step 3 will appear in the System Info screen under Remote Address.
Remote: Basic Remote (Television Only)
  1. Turn the Television On.
  2. Press and hold the TV Power button for three seconds until the LED flashes.
  3. Press and release the TV Power button.
  4. Press and release the Up or Down Arrow on the remote until the television turns off.
  5. After the television turns off, press and release the OK button.
  6. Test functionality with the TV.
  7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Please let me know if you have any other questions or problems. Thanks.
Ray Calo
DISH Internet Response Team
Jun 23, 2011 | DISH Network IR Remote Control
Volume increases to 30 can't turn down
I don't have a solution but if you take off the speaker grille on the front of the set and see two ribbonish cables, unplug the smaller one. The volume will not increase anymore but you cannot use the controls on the front of the tv and the power light will not show green anymore. You can however use the remote to do everything on the set that you would normally do. Hope this helps until I find a real solution.
Sep 05, 2009 | Mitsubishi WS-55511 55" Rear Projection...
After turn on power, navigation icon is not responsive
1st hold on reset button located on bottom right for 3 secs. then hold down power button until the boot menu comes on. then press reboot or update os
Jan 15, 2009 | Nextar X3-03 Car GPS Receiver
TV WONT TURN ON
I fixed it myself. I found that the t6.3 amp/250v fuse had blown. I bought the fuse at a television parts supplier for $2.00 put it in and it worked.Hooray! It has been working just fine now.
Nov 23, 2008 | Sony KV-36FS17 36" TV
Cannot see picture....
you probobaly. need a new bulb, my dad had the same problem. he orderd a new bulb off the internet and now it works just fine
Apr 22, 2008 | JVC HD-52Z575 52" HDTV
GO-Video model DVR440 (DVD/VCR combo) Child Lock ON, No response to POWER button
can only be done by remote control unless you have the complete manual to reset all your saved settings from the front panel
Mar 31, 2008 | Televison & Video
Philips 32PT71B 32" TV Logo
37 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
