Question about Gyration GP9120-001 Wireless Keyboard
I dropped it on the carpet and now it won't power up. The LEDs don't light up.
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Lap top battery charging, LEDs not light but charging battery up to 76 %
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 02, 2012 | Fujitsu Siemens Computers & Internet
Battery charging LEDs not light but charging up to 76 %
Oct 02, 2012 | Dell Latitude X200 Notebook
LEDs on motherboard light up but computer won't start
It still may be dead. Go here and get a PSU tester:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=-1&IsNodeId=1&Description=psu%20tester&bop=And&Order=REVIEWS&PageSize=20
Apr 24, 2012 | Antec : True430 430W P4 ATX Power Supply...
Aod255e wont boot
what is the meaning of won't boot. is your laptop powering on or not. did you see any leds lighting up.
if leds are lighting up then it might be a incorrect ram seating or hard disk might be not connected properly.
if no leds are lighting up. then check your system with the adapter connected.
if it is turning on by adapter connected. then your battery is dead. try to replace your battery.
if you have done all of this. just reset the bios.
WARNING: if you don't have any knowledge of opening a laptop, then don't do the following steps. it is your responsibility for any unnecessary damage.
just open the back cover and reset the bios settings by removing the CMOS Battery inside the laptop.
if you have done this also. take your laptop to ACER service center
Feb 17, 2012 | Acer Aspire One Aod255e-13648 10.1"...
We pulled our stacked washer out from the wall to service the cold water hose filter on the back of the unit. when we pushed it back into it's location the washer won't start, won't fill...
I know you don't want to hear this, but either you did something to the hose filter or you didn't get it plugged back in correctly.
If you banged the water inlet valve in moving it back, it might be damaged.
Suggest you unplug everything and start over.
Sep 04, 2011 | Frigidaire FEX831F Top Load Stacked Washer...
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
Jul 21, 2011 | Linksys Wireless-G WRT54G Router
Hi my tv fell off the wall last night about three feet to the carpet now it won't turn on the amber vizio light won't even come on when I plug it in. I took it apart and nothing appears to be...
After a fall like this (even on carpet) it probably has a cracked circuit board or a loose connector, first (since you took it apart any way) look for all connectors, than unplug them and re-plug them to make sure all plugs and boards are seated correctly, if you still don't have luck, than take out all the circuit boards and check them for cracks under a good lamp and magnifying lens, than repair the cracked traces with a good soldering gun by scratching off the varnish coating and applying solder. (if the crack is to wide you can solder a peace of coper wire to the trace on the board)
Have fun!
Jun 25, 2011 | Vizio L32 32 in. LCD HDTV
Is there a dash light for the gages because replace ignition switch and key and still no display.
Yes, normally there is small bulbs at the back that light up the gauges
Jun 22, 2011 | 1989 Mercury Cougar
Heavy rain leds to water on drivers side floor
you might want to peel the carpet back and check for hole in the floor board. this is not something you can see just by crawling under to look at. Light has to pass through. Carpet pulls up easy from under the pedals, remove thebottom of the door jam like four screws and then you will know for sure.
Feb 11, 2010 | 2004 Acura MDX
Gyration GP9120-001 Wireless Keyboard Logo
26 people viewed this question
Top Gyration Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony Crow
Are you a Gyration Computer and Internet Expert? Answer questions, earn points and help others
