Question about Sewing Machines
I have a Bernina 1130. It is not picking up the bobbin thread. The hook is clean and oiled. the needle has been changed. It was last serviced November 2008.
  • 46 Answers
Make sure you have the correct needle and it is in with the long groove pointing towards you. If the hook shuttle is rotating and you feel a tight spot when turning the machine by hand it means one of the nylon gears has cracked. If a needle has been broken it is possible the needle bar has been knocked up a little, try dropping your needle down about 3mm and turn the machine over by hand to see if it picks up the thread.
Failing that the timing is out, remove the top cober on the arm and loosen the clamp on the hook drive shaft, when the machine is turned over and the needle is at bottom dead centre the point of the shuttle hook should be about 3mm to the left of the needle.
Posted on Jul 02, 2009
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Jun 05, 2008 | Sewing Machines
Bernina sewing machines
Did you mention this specifically to the repairer? Could be a number of things ..... needle, timing, needle clearance to the hook, burred hook...... all of which should have ben checked when it was serviced. Was there a sample (sewn out by the repairer) with the machine when you picked it up? ie to 'prove' it was working correctly.
Apr 29, 2013 | Bernina Virtuosa 150
Bernina 1000 Special sewing machine won't pick up bobbin thread
try tuning the bobbin the opposite way in the bobbin case.
Apr 03, 2013 | Sewing Machines
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
My mother has a bernina 1008 and now that we have taken the bobbin casing out to clean it won't catch when threaded. Any ideas?
Are you threading the bobbin case correctly - the bobbin should rotate clockwise when pulling the thread out under the tension spring. Are you ensuring that the bobbin case is firmly clicked back into position when replacing it. Check your needle is OK. Did you remove the hook from the hook race when cleaning out - have you oiled the hook race ?
Jan 22, 2012 | Bernina Sewing Machines
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
First the simple solution. Make sure your needle is inserted flat side to the back and all the way up.
The only other thing I can think of is that your hook is out of time and this will take a technician to re-time it. You may need to take it in for a servicing.
Jun 28, 2008 | Bernina Virtuosa 160
Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Mar 02, 2008 | Bernina Virtuosa 160
Bernina 801 Sport
Did you clean out the lint under the plate?
Feb 27, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
250 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
