Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Whirlpool washer new..,. washes cold wash cold rinse.. hot wash cold rinse.. but on warm wash is cold wash cold rinse I can send wasdher back just got it t0 day or is there something I can do?
    President:
  • 3,113 Answers
Be sure the hot water valve is all the way opened first. Both faucets must have equal pressure for washer to work properly. They all rinse with cold water, this is normal.
Posted on Jul 02, 2009
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
On rinse cycle...cannot control water temperature...set it for warm but still feels cold to touch. wash cycle is ok. model is whirlpool gold ultimate care II..top loader.
Is the hot water turned on. Remove hose from washer and check screen in water inlet. If it is clear you may need a new water inlet valve.
Apr 01, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Duet ht Washer starts washing fine, it drains then it starts flashing FH and wont take in water for the rinse cycle. It does this for every cycle, it will wash fine but after it drains and is...
The first thing I would check is shut off the cold water valve at the wall and remove the hose at the washer.carefully pry out the little screen in the inlet and clean well,reconnect hose and turn water back on FH is a water inlet issue I am hoping that what is happening is that when the washer starts its wash cycle it is probably filling with warm (hot) and cold water at the same time even though it might be mostly hot,but when it comes time to rinse (cold water ) there is not enough to make the computer happy and you get your FH error.. Hope this Helps,,If not your probley looking at a new fill valve assy
Sep 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Hot water doesnt work, switch to warm and warm comes out.
If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
The clothes in the washer dryer at the end of the wash are really hot and therefore start to shrink the dryer button is not on and the wash is on a 30 degree heat can you help?
If you have washer set for a warm rinse and the cold water inlet screen is restricted you will get too much hot water. Another thing I have seen is if another near by faucet has a sprayer on it and the sprayer is off, but the hot and cold valves supplying the sprayer are on, the hot water can feed back through that faucet and give you an increased rinse water temp in your washer. Also, make sure hot and cold hoses are attached to the proper side of the inlet valve.
Sep 02, 2008 | Whirlpool Washing Machines
Washing machine
Try reversing the water fill hoses
Jan 05, 2008 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
140 people viewed this question
Dan Webster
Dan Webster
Sal De
