The the width of the picture on my Monitor is reduced.
The width of the picture on my Monitor (HP pavilion D5258A) is suddenly reduced, taking up only about 50% of the screen area. it is centered but shrunk. I can find no way to adjust this via the mode controls on the Monitor itself. I am running Windows XP.
This happened recently and the monitor has been working properly for amonths. It appears to not be canning completely across the screen.
  • 121 Answers
Hi
you may click the right button of your mouse and go to the properties.From there you can adjust the screen resolution.
Posted on Jul 01, 2009
Can i adjust the fan speed in the bios on my hp zd8000
You don't have to reduce the FAN speed, because the Fan power works in PWM (Pulse Width Modulation). I.E if the CPU processing is increasing due to high process load, the fan speed changes accordingly to maintain a CPU normal temperature.
May 22, 2011 | HP Pavilion zd8000 Notebook
HP Pavilion f1703 Monitor flickers on & off
Clean and resolder all four round inductors, check the caps, replace them if they have bulging tops (even slightly bulg). Check the transistors (c5707) for shorts. See pictures here: http://s807.photobucket.com/albums/yy352/budm/HP%20F1703/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 25, 2010 | HP Pavilion F1703 17" LCD Monitor
Video problem. Pavilion ZE4805US laptop
Most likely it is either a bad lcd inverter, due to the fact that you have clear picture on an external monitor. The inverter reduces the voltage coming from the motherboard to a lower level in order to power the lcd and the backlight. If this goes bad then you either get a picture randomly, a dim picture, or no picture on the lcd.
Feb 05, 2010 | HP Pavilion Ze4805us Notebook
Hp pavilion dv6810us -- the screen went blank suddenly (no hint of a problem) and can't get it back to normal. I've forced shut off and turned back on (4 times over two days)...still black screen. All...
if it was the video card ...it will appear something on screen like Bios...when accessed..and affect only the installation ...I suspect the lcd connection
so...assuming is nothing inside...take a look on this tutorial
http://www.laptop-repair.info/laptop_screen_repair.html
Nov 09, 2009 | HP Pavilion dv6810US Notebook
Suddenly hor. lin. became "narrowed", smell of overheated element
try a good slap most times it works
u may have to try looking at options to change the monitor soon too, its a sign to say the monitors's getting old
hope this helped
pls rate
Jun 29, 2009 | Samsung SyncMaster 900 SL Plus (White) 19"...
Suddenly my horizontal size on my Dell montoris reduced about 1/3
On the monitor there should be some buttons that allow you to manually configure the width and hieght that the screen comes up with.
Does you screen come up squashed but you can still see everything or only 1/3 of the screen is shown and the rest is black.
Mar 20, 2009 | Dell E153FP 15" LCD Monitor
Reduce the width & height
Open the image in your picture program. click on the option to resize your image which is generally under the heading image depending upon which program you use.. change the dpi to 300 and the PIXELS width to 710. that will automaticaly give you a height. If the picture is "taller" than you want you will need to crop it to get it under 890. Be sure to keep the ratio the same while you are making the changes. there is usually a little box regarding ratio that should be checked. Good luck.
Aug 01, 2008 | HP ScanJet 2400 Flatbed Scanner
White horizontal lines of static on monitor
Can you try reducing your monitor refresh rate to a lower frequency, or the lowest frequency.
Apr 10, 2008 | HP Pavilion F1703 17" LCD Monitor
LCD Monitor Repair
With the computer on and the monitor connected, shine a flashlight at a slight angle on the screen and see if you can make out a picture. If you can, then it is most likely the ccfl inverter, if not possibly the power supply of the monitor.
srich
Dec 10, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
