Question about Uniden Cordless Phone
I purchased the UnidenDECT 6.0 digital answering system, having 4 phones in the pack, and one by one, they are going dead even though I place them back on the units to recharge. Help!
  • 35 Answers
MAKE SURE THE CHARGE LIGHT IS ON, IF ITS ON THEN YOU MIGHT WANT TO CALL UNIDEN CUSTOMER SERVICE YOU MIGHT NEED NEW BATTERIES TO REPLACE UNDER WARRATY.
Posted on Sep 07, 2009
Setting up answering machine for UnidenDECT 6.0
To replace the default greeting with a personal one
( Uniden model D1680 & similar ):
1. press [MENU]
2. scroll to "Ans. Setup" then press [select]
3. scroll to "Record Greeting" then press [select]
4. It will display & tell you aloud to press [select]
5. Speak Clearly your desired greeting, then press [select]
6. press [END] to conclude & exit
Apr 18, 2015 | Uniden DECT 6.0 Cordless Phone
How do I fix base unit battery charging system not property working when I leave hanset on base unit automatic dead when I lft hanset for answer incoming calls?
It is highly likely that your battery pack needs replacing. If you have had it for more than a year and use it often then it is quite possible. You can buy a new one at radio shack online or search for one similar on ebay. Price is about 10 pounds though.
If you have more than one of these phones it may be worth while buying more than one as it will save you postage and might get you a discount.
Hope this was helpful
Jun 22, 2012 | Vtech V2656 Cordless Phone (vtechvt-v2656)
Not receiving incoming calls was talking to my
I used to have this exact model. More than likely, your battery has become "unrechargable". I used to buy replacement handset batteries from ebay every 6 or 7 months. After 3 years, I finally got rid of the phone and purchased a nice Panasonic (just cheaper these days!)
The replacement batteries usually sell for $3 or $4 on ebay. Here's a link of one that's one now: http://cgi.ebay.com/Battery-V-TECH-IP8300-DECT-6-0-89-1326-Cordless-Pho-/330486596555?pt=LH_DefaultDomain_0&hash=item4cf28943cb
Thank you and good luck!
Mar 21, 2011 | Vtech DECT 6.0 Cordless Phone with Digital...
Can you please tell me how to shorten the amount
Got it, and you can set it for 2, 4, or 6 rings on incoming calls.
1. Press MENU/CLOCK on the base to enter setup.
2. Press MENU/CLOCK repeatedly to select RING TIME.
3. Press VOL:/SELECT to set the number or rings at 2, 4, or 6.
4. Press SET to save the setting.
You can download and print the operating manual for youir phone system at
http://www.uniden.com/pdf/DXAI8580-2om.pdf
Dec 11, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Phones stopped working. They only read
first step is to unplug all power and phone connections from the wall for all Vtech phones and bases.
Second,plug each set and base in the wall for power one at a time.
Go back to the basics and pair the handset with the base of the unit.
Do this for all sets one at a time.
May 29, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I'm not familar with the Vtech but I would suspect that all 4 units work off of the answering machine base. It sounds like it is seeing a dial tone.
Take a working phones like the wall phone, if it is easily removed, and use a known good connecting cable between the good wall phone and the jack that the Vtech is plugged into.
If that works, take the connecting cable loose and replace it with the Vtech connecting cable. If that works check the jack on the Vtech for crossed wire. If non found, connect it to the jack the wall phone was plugged into. If this doesn't provide satisfaction, let me know exactly what you did and what happened and we will go from there.
May 28, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
My phone is dead
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
<KEYWORDS="RESET, call,? can?t tone, dial no flashing, unavailable, range, of out working, not up, messed>
May 05, 2009 | Uniden Cordless Phone
Searching for base and battery loses power too soon
Have the batteries been changed since the system was purchased... 4 years is a fairly good usage for batteries in that type of use.
Good news you should have no trouble buying replacement batteries... even walmart has them. Open the back of one of the phones... the battery has a small plug.. pull that out and you will see the part number... about 25 dollars each battery pack... cheaper if you are in the states.
One note tho... when you replace the battery pack you need to charge it for at least 12 hours prior to the first usage 24 hours even better.
Robert
Dec 19, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden Cordless Phone Logo
60 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
