Question about LaCie (300770) 250 GB Hard Drive
Lacie edmini 250 GB will not power up
I have had this unit for about 5years without bother, until now that is.. the power cord seems fine and iluminates the transformer light, but when switching on at the main unit ie. the blue button it flashes on for a brief second before going out. There is no activity from the fan or hard drive motor, other than this quick flash of light each time its pressed, it seems quite dead. I use this drive to back up all my music and photos and would be horrified to loose all this data which was the main reason for buying it. Is there anything you can suggest before I try to locate a lacie repair centre in the uk.
  • andypt871 Jul 01, 2009
    I have just received a reply solution from coldsilver20 which I am greateful for as it gives hope that the data is not lost, but I omitted to mention that our househould only uses laptops hense why we use this ethernet hard drive as a shared backup drive.
    Novelist:
  • 113 Answers
Sounds like a faulty power circuit within the external housing. remove all screws and the drive from its housing. you now hold in your hand an internal hdd. remove all jumpers, if any are present, and install this drive on the same cable as your master hdd. now when u boot up to my computer window, you will see two hdd named C: and D:
Posted on Jul 01, 2009
Hello. I have a LACIE EDMINI-V2 that won't start, no disk noises, no light from led in front button, nothing. I have dismantled the box, connected the disk drive to my PC and its ok, measured the 5V and...
I owned one just like this and the power supply failed at about 1 year. It turns out it's a fairly common problem. Since you have the device open, does the controlboard/motherboard look burnt at all?
If it is not damaged, you may be able to buy a replacement power supply here: http://www.lacie.com/products/range.htm?id=10030
If it is damanged, then you may still be under manufacturer warranty, contact Lacie here: 503-844-4503 sales@lacie.com
Please leave feedback for this answer, thanks.
Mar 09, 2011 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Same problem
uninstall the driver and reinstall it or do a driver rollback,via your device manager(XP)
Sep 01, 2009 | LaCie (300770) 250 GB Hard Drive
I can't connect to Edmini via LAN nor USB. LAN computer doesn't detect then I tried to check edmini from browser then I get this message /www/cgi-bin/public/sharelist: line 246: cannot create temp file...
Just contact www.lacie.com great support. there answer for my drive was to upgrade the drive version and to reboot the drive. Maybe the last thing is enough. For me it worked.
If necessary update driver http://www.lacie.com/nl/support/drivers/driver.htm?id=10156
Follow the procedure below to reset the Network Space to factory defaults:
  1. Move the power switch to the OFF position. Wait for the drive to shut down.
  2. Turn ON the drive.
  3. Within about 3 seconds, flip the switch OFF and On several times.
  4. Immediately turn it ON
If the light flashes quickly, the unit is resetting itself. Attempt to connect to the drive again after about 1 minute using the default username and password (by default, they are both admin.)
Jul 29, 2009 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
Dead hard drive
Try unplugging the usb connector and plugging it back in. Your pc shouls recognize the installed component automatically. Also, some external hard drives work like normal pc's do: hold the power button in longer until something happens. Hope this helps.
May 24, 2009 | LaCie (300770) 250 GB Hard Drive
Hello, I have a Lacie 330770 250 GB hard drive.  It does not respond when I plug it into the outlet.  I have tried several different outlets in different rooms, and neither the green light on the power...
If the green light on your LaCie power supply does not light, you likely have a bad power supply. You can buy a new one from LaCie. If you are purchasing a new power supply from LaCie ask for the higher wattage unit. LaCie upgraded this a while back.
Jan 26, 2009 | LaCie (300770) 250 GB Hard Drive
Problem with LaCie 500 GB d2 Quandraq
Contact Lacie support for a new power supply. I had the same problem, contacted Lacie support, they sent me a new power supply with power cord and all is well now.
Sep 22, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Sep 01, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie drive
I got the same problem mate, im going to a computer store tomorrow and found out what to do , ill email you first thing tomorrow avo when i find out
Mar 22, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie (300770) 250 GB Hard Drive Logo
550 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
