Question about Dryers
I have a whirlpool dryer, model number GEC9858EQ0, that did not restart after opening door to check the laundry. I have ohms checked the start switch and door switch. where do I go next?
  • 2,071 Answers
It blows fuses or trips the circuit breaker Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
    Good luck
  • Regards:
  • VOTIT
Posted on Jul 01, 2009
Whirlpool dryer duet quit during drying cycle everything lights up works is normal except it will not turn on when you push the start button it just makes a click sound in the back of the machine
Whirlpool Duet Dryer - turns on, clicks, won't run
you may need a technician if you are not savy with electrical testing but here is your route to fixing and by all means unplugg first
  • #1Alwckw4
    Premium Member Join Date Sep 2013 Location Florida Posts Whirlpool Duet Dryer - turns on, clicks, won't run
    Model Number: GEW9250PW1
    Brand: Whirlpool
    Age: 6-10 years
    My dryer turns on but when I click start, it simply clicks, but doesn't run. Any ideas would be greatly appreciated.
  • September 10th, 2013, 12:14 AM#2 Jake
    Appliance Tech - Admin Join Date Aug 2004 Location McMullen Valley, Arizona Posts
    Ok, lets first check your thermal fuse.
    You would need to take off the lower front access panel under your door, then take off the duct assembly#45, by removing the two #11 screws as shown in your parts diagram here: Bulkhead parts for Whirlpool GEW9250PW1
    Unplug or turn the breaker off to your dryer first before opening it up and ohm testing.
    Then you will need a multimeter to ohm your thermal fuse. Its #59 in that parts diagram, take both wires off the thermal fuse first.
    Here's the thermal fuse for your model you can order here if needed:
    Thermal Fuse WP3392519
    This video shows how to test it:
    Let us know what you find.
    If the thermal fuse tests good, We've had a few members report door switch problems.
    You can check it for continuity with a multimeter to make sure.
    Here's that door switch you can order:
    Door Switch WP8283288
    It shows on Page 4-6 in your repair manual I posted a link to below how to access it to check/change it. Make sure your dryer is unplugged!
    Push the button in on the door switch with one meter probe on COM and the other meter probe on NO and see if it reads. Normal ohms is 0-1.
    If the thermal fuse and door switch check fine, then its the control board.
    Here's the control board for your model you can order here:
    Main Control Board WP8546219
    I'm attaching the repair manual pdf for the Whirlpool Duet dryer below.
    It shows how to get access to the control board on page 4-2 through 4-4.
    Unplug or turn the breaker off to your dryer first.
    below is a link to the manual
https://www.applianceblog.com/mainforums/attachment.php?attachmentid=12424&d=1378793669
Feb 03, 2018 | Whirlpool Dryers
Roper electric dryer wont start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Feb 09, 2016 | Roper Dryers
I have no light. Unit is completely dead. I have tested the outlet and I have 250v between A & B slots and 120 between A & C and B & C. I believe the fault is in the machine, I am just
Sep 30, 2014 | Whirlpool WED7500VW Laundry : Dryers
Kenmore dryer model 110.74994300 push start does not stay on
Kenmore Whirlpool Dryer Won Start Easy Fix
Jul 01, 2014 | Kenmore 62602 Electric Dryer
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Jun 21, 2014 | Kenmore 659 Electric Dryer
Ler7646 jqo whirlpool dryer
broken door switch,if the dryer hasn't been cleaned out and you changed out the thermal fuse could be one of the t-stats on the heater box,the model number you sent doesn't come up,
Ler7646jqo,open the door,you'll see a tag with the model and serial numbers,on the frame around the door opening.you'll need an ohms meter to check the parts,you have to remove at least one wire going to the part you're checking with the machine unplugged and check the part for continuity,if the dryer hasn't been cleaned out most likely the high limit thermostat on the heater box.if you don't clean out the dryer and vent line it will pop again until the dryer is cleaned,the dryer is running to hot from the lint blocking the air movement and the fuse pops as a safety device so you don't have a fire.
Feb 19, 2013 | Whirlpool LER4634J Electric Dryer
My Kenmore Dryer model # 110.65942401 will not start. The door switch seems fine. When I hold the start button in I can here the timer clicking, that's it. Any suggestions? Thanks!
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com What to Test When Whirlpool or Kenmore Dryer Won Start or Run
Apr 29, 2011 | Kenmore 659 Electric Dryer
Dryer was running. I opened the door to check the load and the dryer would not restart. I buzzed, but did not turn. Some smell of over heating. next day before I started to trouble shoot, I attemped...
Usually a dryer that will not start is the door switch. The switch is simple to change and comes in different styles. Some have a screw or two to remove and some without screws you just pry out to replace. To replace open the door and you will se a button that closes the switch when the door is closed. Depending on the type remove screws or pry the switch out. Your local appliance dealer has these switches cheap. Take your with you as well as the make and model number to buy a new switch. Reinstall and all is well. Hope that helps and thanks for asking Fixya.com, Rich
Nov 21, 2010 | Whirlpool LER4634J Electric Dryer
Dryer will not start after bulb burned out.
moch, the fact that the light is staying on when the door is closed leads me to believe that the door switch is the culprit. If that switch is not made you will not start. See if the pin is broken off. Start there and let me know. Catriver.
Aug 10, 2008 | Whirlpool GEW9200L Electric Dryer
Dryers Logo
207 people viewed this question
Top Dryers Experts
