Question about Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive
How do i turn the rear interior lights off when the back doors are open?
  • iankaren378 Jul 29, 2009
    yeah i do i have a screwdriver to keep it in but if i forget the battery gets drainid... :0(
Push light switch in
Posted on Jul 27, 2009
GO TO THE WRECKERS AND GET A LIGHT WITH AN ON OFF SWITCH , I GOT ONE FROM AND OLD XA FALCON WAGON I HAD TO MAKE HOLE BIGGER BUT WITH THE SWTCH I CAN TURN IT OFF WHEN I OPEN THE DOORS AND DON'T NEED IT ON , I AM AFTER ONE FOR THE DRIVERS CONPARTMENT AT THE MO SO I'M BACK TO THE WRECKERS NEXT WEEK
Macca
Rev 14:6-12
Posted on Aug 07, 2009
Where is the location to replace overhead lights fuse in 2003 oldsmobile aurora
Rear fuse box. INT LP 10 amp . there is also INT LP relay in the same rear fuse box .
Fuse Block - Rear
Under the rear seat, on the left side of the floor pan
The INT LP fuse in the fuse block - rear supplies battery positive voltage to the normally open switch contacts of the INT LP relay. The INT LP fuse also supplies battery positive voltage to the INT LP relay control circuit. The fuse block - rear also supplies battery positive voltage to the relay control circuit for the front courtesy lamp. The door modules communicate on a simple bus interface (SBI). When you open any door, the switch contacts of the door open switch close. When a door open signal circuit is grounded, that door module sends a message to the drivers door module (DDM) in order to indicate that a door is open. The DDM sends a class 2 message to the rear integration module (RIM) in order to indicate which door is open. The RIM activates the INT LP relay in order to provide battery positive voltage to the interior courtesy lamps. When any front door is opened, the RIM will energize the FRT CTSY lamp relay grounding the I/Pcourtsey lamps at G302. Depending on which doors are opened, front or rear, the proper interior courtesy lamps illuminate. The RIM provides a pulse width modulated ground to all interior courtesy lamps for the interior lights theater dimming feature. Some of the courtesy lamps are also used as reading lamps, each reading lamp may be manually turned on or off using it's own respective switch
Sep 24, 2015 | Oldsmobile Cars & Trucks
My interior lights won't go off. There is not a door open or a light on.
check your light dimmer and urn it back just a bit, you have accidently turned you interior lights on.
Jan 20, 2015 | 2004 Lincoln Aviator
My door open sensor is playing up on the rear door (boot) as i am driving down the road the interior lights will come on and off as if the rear door is being opened, the door is securely shut so i bel
its a switch with a rubber cover on it you can push it in and out, may just need a clean with some wd40 as they rarely go unless water is getting in the back of them.
Dec 28, 2017 | 2006 Mercedes-Benz Vito 112
2002 Grand Caravan. Overhead console lighted switches are not lighting. The Map lights that shine straight down works but none of the others back lights. Side door switch,rear gate switch, garage door...
The first thing that comes to mind is that the dash lights scroll dimmer is scrolled all the way in one direction which manually shuts off all the interior lights, even if a door is opened. At night turn on the parking lamps and then scroll the dash lights dimmer until the dash, radio face, overhead console, etc is brighter. Turn off the headlamp switch. Shut off the engine and exit the vehicle. Interior lights on? Hope this helps.
Jan 26, 2018 | 2002 Dodge Grand Caravan
How do I turn off the interior light and keep the back hatch open? We love going to the drive ends but the inside lighte wont turn off...
I do this almost daily, while working on or cleaning cars. Open drivers door, put key in ignition so that the chimes are dinging. Now, look at the latch on the open door, you can see a "U" shaped latch arm, using a screwdriver, pretend its the striker on the post, and push the latch arm back until it clicks twice. The dinging should stop, and the interior light will go off, just as if the door was closed. Now, if the latch on the rear hatch is similar, you should be able to "trick" it the same way.
Before you attempt to close the door(s) or the hatch, pull the handle as if you were opening it. The latch should pop back to it's "open" position. If not use the screwdriver to pull on it while pulling the handle. Do let me know if your now "IN THE DARK"!!
Aug 27, 2011 | 2006 Chevrolet Equinox
Interior lights in my 98 grand cherokee won't turn. No open door signal and it's not the rear dome light switch turned on.
dimmer switch on the dash... lower it. it should click and should shut off the interior lights.
Jan 04, 2010 | 1997 Jeep Grand Cherokee
I have a 2000 Pontiac Grand Am and the interior stay on
Interior Lights Circuit Description
By using a feature called inadvertent power control, the body control module (BCM) supplies power to all of the following components:
• The courtesy lamps
• The dome lamps
• The rear view mirror reading lamps
• The instrument panel compartment lamp
• The rear compartment lamp
The left front door ajar switch turns the interior lamps on through the BCM by grounding CKT 394. When the left front door is open, the switch is closed. This condition provides a ground and a door open input to the BCM. The BCM then grounds the following lamps through CKT 156 in order to turn the lamps on:
• The dome lamp
• The rearview mirror lamps
The right front door ajar switch and the rear door ajar switches turn the interior lamps on by grounding CKT 395 from the BCM.
When the ignition key is removed from the lock cylinder, the interior lamps remain on for approximately 40 seconds.
The BCM provides an interior lamps-on delay after a door is opened. The lamps remain on for approximately 40 seconds or until the ignition switch is turned to the ON position. The 40 second lamps-on delay reduces to 4 seconds if a door is opened within 2 minutes of the ignition switch being moved from the ON position. The interior lamps immediately turn off when the vehicle begins to move.
The dome lamp OFF-DOOR-ON switch controls the dome lamp. When the switch is in the OFF position, the dome lamp remains off. When the switch is in the DOOR position, the dome lamp lights when a door is opened by the BCM grounding CKT 156. When the switch is in the ON position, ground is supplied through CKT 750. The rear view mirror reading lamps are controlled by the rear view mirror reading lamps switch or through CKT 156 from the BCM.
Voltage is supplied at all times to the BCM through the INT LPS fuse. The BCM supplies voltage to the interior lamps through CKT 1732.
Battery Run Down Protection
When the ignition switch is in the OFF position, the BCM turns off the power to all of the interior lamps after 18-22 minutes.
The BCM will reset the inadvertent power control relay output when one of the following actions is performed:
• Open or close a door.
• Turn the ignition switch to the ON position.
• Turn off any interior lamps that may be on.
• Press the power door lock switch/keyfob button.
• Press the decklid release keyfob button.
Courtesy or Dome Lamps Always On
Step
Action
Yes
No
Did you perform the Lighting Systems Diagnostic System Check?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Lighting Systems
Use the Scan Tool in order to command the courtesy lamps OFF.
Do the courtesy lamps turn OFF?
YES - Go to Step 4
NO - Go to Step 3
Test for a short to ground in the courtesy lamps control circuit (156). Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
YES - System OK
NO - Go to Step 7
Test for a short to ground in each door jamb switch circuit:
• Circuit 394-Driver door
• Circuit 395-Passenger door(s).
YES - System OK
NO - Go to Step 5
5
Test each door jamb switch for proper operation. Refer to the following:
• Open switch with the door closed
• Closed switch with the door open
Did you find a malfunctioning door jamb switch?
YES - Go to Step 6
NO - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
6
Replace the malfunctioning door jamb switch. Refer to Door Jamb Switch Replacement in Doors.
YES - Is the repair complete?
NO - System OK
7
Important: Perform the set up procedure for the body control module.
Refer to Body Control Module (BCM) Programming/RPO Configuration .
Replace the body control module. Refer to Body Control Module Replacement in Body Control System.
Did you complete the replacement?
System OK
Instal the door jamb switch wire harness.
Install the door jamb switch (2).
Feb 24, 2018 | 2000 Pontiac Grand Am GT
Door sensor
Will pushing on the door-closed switch turn off the alarm? If it does, extend the button with something glued on to it so that the door will operate the switch. If the switch is damaged, it will need to be replaced.
Sep 11, 2009 | 2000 Chrysler Cirrus
Interior light stays on and door warning lamp
some where along the edge of the door there is a push button switch that is deactivated when the door is shut, turns light of and turns door warning lamp off. either at bottom rear of door or up by the hinges.
Aug 25, 2009 | 2000 Ford Ranger SuperCab
My interior lights will not turn off the dome light and rear bay light
check your door jamb switches to make sure they are shutting off the interior lights. They are part of the door latch.
All models have a lamp switch (13713) located in the driver's door latch that activates the interior lamp when the front door (20124) is opened.
I believe right door has one too, and maybe the hatch latch too
Aug 10, 2009 | 1996 Ford Explorer
Enlight Combo (5601908) (Beige) (5601908) CD-RW/DVD-ROM Combo Drive Logo
129 people viewed this question
Top Enlight Computers & Internet Experts
gaucherre
Jerry Umali
Raymond Solomon
Level 1 Expert
Are you an Enlight Computer and Internet Expert? Answer questions, earn points and help others
