Question about Oconnor Photography
I have two O'connor model 30B tripods and I am having problems with the fluid heads.I get jerky motion when I pan. Where can I send them to get repaired?
Http://www.bealecorner.com/fx1/OConnor30/index.htm
look here for detailed pictures of what's inside and a suggestion as to waht kind of grease to use
Posted on Sep 05, 2009
How do i take the fluid head apart
Probably by undoing various screws, allen bolts etc, but I would advice approaching this with great caution, as they are precision items and it would not take much to render them both useless. Apart from other considerations, how is the fluid contained within the head ?
May 02, 2016 | Sachtler SYSTEM-FSB6-TV2 Fluid Head FSB 6T...
Targus Tripod TG-P60T is binding while panning horizontally, how can I resolve this issue?
There are two issues I'd like to help resolve here.
They are 'binding while I'm panning' and 'binding when I start to pan'.
Binding while I'm panning...
There is a large knob on the side of the panhead that needs to be loosened slightly. I have seen some folks loosen the panning handle because they believe it to release the panning mechanism.
Also, be sure that the camera you are using is not too heavy. There's a 5lb (2.2kg) limit and that can also cause undue strain.
Binding when I start to pan...
When panning, I advise our students to begin their pan a couple of feet ahead of the actual scene they'd like to pan and finish a couple of feet after the scene. This allows for a smooth pan after you overcome the inertia in getting the pan head to move and doesn't result in a jerky stop. It's straightforward to edit out these lead in and lead out sections.
Hope this helps.
Sep 24, 2014 | Targus Red Tg P60t Pro Series 3 Way...
How should fluid heads be stored?
Alisa: With all 'video tripod heads'...., regardless if the are the original 'true' fluid heads (that actually used a liquid (oil) to achieve 'fluid' type movements) or a modern professional 'fluid' head (that actually uses a clutch mechanism like a cars transmission) or a fluid effect head like the Manfrotto #501HDV (which used nylon discs sandwiching a ball bearing race)...., always store with the pan and tilt mechanisms unlocked!!!! This means the camera platform should be positioned in the 'rest' position (not tilted forward or backwards), also ensure that any counterbalance mechanism is released so as to eliminate strain on the internal mechanisms!!!!
If you remember to do this and don't overload the head..., you will extend the life of your gear significantly
Peter
Nov 12, 2013 | Manfrotto 501HDV Pro Video Head Tripod
What fluid do i need in my 3066 tripod
they don't use fluid - maybe some grease in the tilt and pan of the head, but the tripod itself doesn't need any.. you might need an adjustment somewhere... I own 3 of these.
Feb 07, 2013 | Manfrotto Bogen 3068 Tripod With Bogen...
How can I fix the jerky motion of the 804RC2? What kind of lubricant can I use on the head?
Parts and a diagram can be found here: http://www.manfrottotripodparts.com/head804rc2-3.html
Silicon grease in very small quantities is the best lube to use. DO NOT use oil or liquid lubes like WD-40. These will flow and make the head messy and may "wash" the other lubes away.
Jun 09, 2011 | Manfrotto BOGEN 804RC2 Basic Pan Tilt Head...
Velbon DV 7000 replacement parts
Hi I need a locking clip for one of the Velbon Tripod legs any suggestions?
cheers
Wayne
Apr 15, 2009 | Velbon Sherpa DV7000 Tripod
FH101 head jerky panning movement
Not knowing where you reside, I don't know if a certain product is available to you but there are several different brands and some generics in the US. The original oil additive was called STP, there was a competing brand called Motor Honey (shudder) and in many auto supply houses you can find a generic sold for 'high mileage engines.' It is a refined petroleum product with a very high viscosity and is sticky in nature. If you can access the surfaces causing the problem, a dot ot two on either will probably help with the jerkiness you are having. I have used the stuff for similar gliding surfaces and the only disadvantage is the tendency to 'creep' so keeping the applied quantity low is a must.
Mar 08, 2009 | Swarovski Optik Swarovski Tripod 2 with...
SLIK 512QF tripod
Carole31,
I have the same tripod, and the screw shown in the photo you posted is to lock down the rotation of the tripod's head, i.e., what a video camera uses to pan (horizontally) across a scene. The large knob is used for the same in the vertical direction (up and down motion).
Jun 12, 2008 | Slik Photography
Pan control not fluid when tension increased
Sounds like you might have gotten some dirt trapped under there. You might try to loosen it and blow it clean.
Apr 16, 2007 | Sunpak Video Pro M Tripod
Photography Logo
377 people viewed this question
Top Oconnor Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you an Oconnor Photography Expert? Answer questions, earn points and help others
