Question about RCA P52937 52" Rear Projection Television
Problem with screen?
When we first got the television it worked fine, but about 6 months a swirl like mark that resembles a half moon its a combination of red green and blue, and in a couple of months another one appeared so there is a total of two of these "marks"
  • 1,139 Answers
Re: Problem with screen? - RCA P52937 52" Rear Projection Television Projection Televisions
This might be a convergence module issue
Posted on Apr 24, 2008
0 characters
3 Points
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Half moon shaped lines
your convergance board is about to go out. thats what happened to mine. it will cost about 300 dollars to get it fixed
Aug 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Colors out fo alignment
The convergence circuit is having a problem. This can be either bad connections at the pins of the convergence ICs or defective ICs. These are large black ICs attached to a heat sink and should be marked STK-XXX. If you can solder, try resoldering the pins of these ICs first. If that failes to resolve the problem, replace the ICs. The should be no additional alignment necessatry once the ICs have been replaced.
Jun 10, 2008 | Hitachi 53UDX10B 53" Rear Projection...
RCA Projection TV model #p61926
The convergence circuit is your problem and most times with this model the convergence power supply bd. is the problem.
Feb 11, 2008 | RCA P46921 46" Rear Projection Television
get an estimate to fix your convergence problem
Oct 08, 2007 | RCA P52937 52" Rear Projection Television
Sprayed Screen
Take a look at this relevant post:,p211196/RCA-P61927-61-in-Rear-Projection-Television.aspx It's possible that the cleaning agent in the spray has dissolved the screen. If it is the lenticular lens(the vertical lines) there will always be permanent marks from the spray until it is replaced. You can try a toothbrush, dry and carefully scrape the material out of the grooves. there's also the Endust Product made just for this type of thing, It's called Endust for Electronics, and I heard it works like a champ. Another option is a dry-cleaning solvent, trichloro-ethane, which you can find at many hardware stores. This will wipe crayon marks right off of glass without any scrubbing at all. Plus, it's harmless to most plastics. Also heard of a product called Tough and Tender, that should be ok with a screen. you better consult JVC on any material you plan to use though. Major problem is in case the spray dissolved the screen. Don't be hard on the kid, encourage him and he might be a great graffiti artist ;]
Jun 09, 2006 | JVC AV-65WP55 65" Rear Projection...
RCA P52937 52" Rear Projection Television Logo
Top RCA Projection Televisions Experts
The Wyzzyrd
D. E. Hev
Ron Dufek
Ron Dufek
Are you a RCA Projection Television Expert? Answer questions, earn points and help others
