Fans run most of the time after I removed them to clean and then replaced them.
    Sergeant:
    Champion:
  • 212 Answers
The fan will run if the hard drive or mother board get hot. as long as it is running You will be okay.
Posted on Jul 01, 2009
My figidaire freezer fans runs almost all the time
Your problem could be as simple as dirty condenser coils or a burned out condenser fan. These components are on the bottom of the refrigerator and removing a couple of panels should give you access to them. Clean dust and dirt off the coils and check to see if the bottom fan is running when the refrigerator is running.
You'd be surprised how often this simple fix will get you back up and running. Dirty coils make the refrigerant system VERY inefficient, sometimes to the point that the refrigerator has to run almost constantly to acheive the desire temperatures inside the refrigerator.
Mar 16, 2013 | Refrigerators
Amana ABB2221WH the fan in the inside roof of my refrig. is clicking/vibrating when the motor runs. What is wrong and how can I learn how to remove the light cover unit to get to the fan...
it needs replacing if ur frig is under warranty see to have it fixed if not write down your model number down and replace it most of the time it needs cleaning and might be off balance and hitting its housing, i try cleaning it with compressed air or shut the frig off removing it and cleaning the unit.
Apr 09, 2011 | Amana ABB2221WH
Desktop computer fan runs constantly
Desktop fans do run constantly, you cannot avoid this.
The reason they get loud is because there will be a build up of dust on the fan blades.
To rectify this problem turn off the computer and remove the power cord from the rear. Then you need to remove the side panel from the base unit to expose the motherboard.
You will see that inside the case it is full of dust. Look at the CPU fan (the fan on the motherboard) also take notice of any case fans too, they are at the back.
To clean the fans and the case you can use a clean dry paintbrush or compressed air.
Once the inside of the case is cleaned you will see a noticeable drop in noise.
Regards.
Jul 03, 2010 | HP Compaq Presario SR2150NX PC Desktop
Inside fan never shuts off. Freezes fine.
The fan is controlled by the by the electronic control located in the back by the compressor.
If the fan is running all the time there is something we need to determine before replacing parts.
Is the compressor also running all the time? The inside fan should run at the same time as the compressor, if they are both running then check and clean the coils behind the freezer. If they are clean and both running then check the door seal to make sure it is not broken or torn. If all these are okay then the compressor is just wearing out and getting inefficient.
If the compressor is not running and the inside fan is running the problem is within the control board down by the compressor, this is a replace only component and runs about $180.00
Apr 22, 2010 | Frigidaire 20.3 cu. ft. Upright Freezer...
The laptop overheats, the fan starts overworking, and the touchpad can no longer reliably control the cursor. If I turn off the computer, detach and reinstall the battery, and let it cool down for a...
as you said the laptop over heats and the fan overwork probably the fan is not running on the speed to cool the laptop this leads to the reduction of your processor powerformance hence making it hug.
please remove the fan and clean it. remove the dust and also clean the inside fan its motor needs to be cleaned. this will help you to buy time as you prepare to replace it. if this fails please replace the fan a soon as possible.
Dec 05, 2009 | Sony VAIO VGN-BX640P PC Notebook
Do I need a new fan blade if I replace the fan or will the old one go back on fairly easy? Ecoquest fresh air
If you need to replace the fan motor, the fan blade can be removed by grasphing the center hub of the fan and pull the fan straight out of the purifier. I remove it every time I clean my machine, since it easy to clean it once it is removed.
Nov 21, 2009 | Ecoquest Fresh Air Air Purifier
R.kerr
Fan some times makes ratteling noise when it is old and dusty. If you know how to open it remove the fan put some oil in the bearing of fan give external supply to fan and run it for 5 mins. clean the ventilation behind fan if noise goes by oil it is good or replace the fan.
Nov 12, 2009 | Microwave Ovens
Unit never seems to stop running, always running
There are several things that could cause this issue. If you have a condenser fan underneath the fridg that has stopped running due to poor lubrication, maybe debris blocking the fan blades or a dirty condenser especially if you have pets. You can clean the **** from under the fridg (remove the grill on the front and vacuum out) or if the fan is not running with the compressor as it should repair or replace it the fan motor. Also a worn out door gasket can cause excess run time.
Jun 26, 2009 | GE Refrigerators
Fuser fan error?
The fan is likely bad. Time to replace.
Feb 22, 2008 | Xerox Phaser 7300DN Laser Printer
Not cooling
Replace heater and defrost timer
Aug 09, 2007 | GE Profile PSW26P Stainless Steel Side by...
Computers & Internet Logo
16 people viewed this question
Alun Cox
David Payne
David Payne
