Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
I have a new 1 HP Hayward superpump. The pump
I have a new 1 HP Hayward superpump. The pump starts and runs for about 3-5 secs and then shuts off. The shut off results in the circuit breaker triping. The voltage stays above 230V until the the pump shuts down. The owners manual suggested that shut down is the result of low voltage but I have ruled this out. I am thinking the pump may be bad.
Any other suggestions.
  • Pete May 11, 2010
    Is the pump set to the 230v position?
  • 708 Answers
Would also think pump bad.
Posted on Sep 05, 2017
rickzilla
  • 706 Answers
SOURCE: frig trips circuit breaker
Hello gonzomg69,
The two other comments posed at you from Blue Dog and 20YRSEXP are good ones and necessary to get to the root cause of the problem however I have a few ideas to share with you that may help.. First off, I am assuming that the circuit breaker you mention is the one that protects the outlet that feeds your fridge power. If thats correct, and you just started to have breaker trips, the obvious question is ..does that circuit breaker also supply power to other receptacles and do those have any additional appliances or 'loads' on them that are drawing current? The circuit breaker current rating is based on the wire size so that regardless of what you plug into a receptacle, that breaker limits current so you won't melt the insulation or have a fire. Also, you should be aware that circuit breakers do go bad and that may be your problem too..
I hope this information helps you...
Regards,
Rick
Posted on Nov 29, 2008
  • 93 Answers
SOURCE: my hayward pool pump started making a humming
check impeller by turning shaft with pliers sounds as if its stuck do this while of and try to restart
Posted on Jun 18, 2009
john224
  • 1378 Answers
SOURCE: new hayward 1 HP super pump runs 1 or 2 seconds,
Check that the motor is set for the proper voltage. They are usually factory connected for 230V and if you have a 115V line feeding it the motor will overheat and cycle the overload as you describe.
Posted on Jul 04, 2009
  • 93 Answers
SOURCE: Going from 230v to 115v on Super Pump
open back you will see the bars to hook to it should show which is the right side 3wire only for 115
Posted on Jul 13, 2009
  • 6 Answers
SOURCE: i mistakingly switch the voltage to 110v instead 230V
You are going to have to replace it....obviously. Here are some places that popped as having the supply you need. I have never used any of them personally.
Dell Optiplex Gx1 Gx110 145w Desktop Power Supply 5554t
$14.99 used - eBay Dell 11VTW Optiplex GX110 SFF 110W Power Supply (See 1728P)
$35.00 refurbished - Used-pcs.comNEW Dell Dimension XPS OptiPlex Power Supply, 200W, Dell 824KH
$19.97 new - TXcess Surplus
Posted on Oct 07, 2009
Why does Pump lose its prime and won't prime again after shutting down
you have a leak in one of the intake unions make sure to use pool lube if those ok check pump top seal or chlorinator top keep checking youll find it if not need more info
Aug 17, 2014 | Hayward SAND FILTER, PRO SERIES
How to change rotation on hayward pump
these pumps are designed to run in one direction
Jan 29, 2014 | Hayward SUPERPUMP 2.0 HP, 115/230V
Overheating hayward super pump
Superpumps have been a workhorse in the industry for decades. Your results are highly unusual. The motors that run these pumps have bee manufactured by Century/Magnetek and A.O. Smith for the past 20+ years. These same motors power the vast majority of pumps built by a wide range of pool pump manufacturers. (They are not Hayward specific)
You may want to get a second opinion from another electrician, or call out a pool pro to check out the installation to see what could be causing these frequent failures. This is WAY abnormal.
Jul 03, 2013 | Pool & Spa
New hayward super pump trips 20 amp breaker after a few seconds
Use an ammeter that clamps around the wire to see how many amps it pulls. It sounds like a weak breaker.
Apr 01, 2013 | Hayward SUPERPUMP 2.0 HP, 115/230V
I just installed a New 1 hp Hayward Super Pump. The electrical service is a 20amp GFCI breaker> Old pump was a plug in connection, re-used the existing wiring. I changed the internal connection on the...
I see what you said ... still I want to say the following: It is to your benefit to keep the motor at 220 VAC ... Since you want to run it on 120 (I presume the motor is internally wired for 120 now - right?) did you change the white wire in your pannel to the neutral bus making the line 120? Also check the motor that it is wired for 120. It sounds to me like you did the line but not the load.
If the line and the load are both correct the next thing to check would be the start capacitor. It should be good since this is a new motor ... but it is not running. Have it checked.
May 24, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
How do i take apart a hayward superpump 115/230V serial number c48l2n134b1?
i have a hayward 3/4 hp model c48l2n134b1 motor when i turn it on runs fine heats up and shuts off smells like somthing is burning
May 22, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
I am replacing my Hayward 1 HP superpump. The old pump had the 230/115 conversion plug on line 1. The new pump has it on line 2. Do I jusst connect the 115 v(hot) wire to line 2? That would be oppisite of...
It will not matter where you put the hot and neautral as long as one goes on line 1 and the other on line 2. Just be sure to reset the voltage indicator to read the 115V like before and your all set.
Oct 19, 2009 | Hayward 1.5hp 230v 2 Speed Uprated Super...
Pump is leaking from the bottom what do I need to do to fix it? Only leaks when running, also looses prime when turned off.
The mechanical seal. We sell them for about $4 or you can get them locally. The superpump uses a 201 seal.
Jul 16, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
I'm need assistance wiring my hayward 2 speed super pump up with my pool timer. the pump is working now but it's running real hot and making alot of noise.
You may have a faulty bearing ... causing the noise. The pump is actually water cooled. Do you have 2 inch line for your 2 HP pump? Small pipe makes the pump work harder. If your lines are smaller, you may want to consider a smaller pump.
the motors will run pretty warm.
Run your pump on high for best results.
If you are using a timer ... you will need a double pole switch to turn it off if it is setup for 220 VAC (which it should be, for most econimical operation)
Jul 08, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
862 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
