Need part number for rubber boot on my kenmore elite HE3t washer
My rubber boot on my kenmore elite HE3t that I have had for five years is full of mildew I can't get out. What part do I order to replace this? Model number 11042926202
  • Jim Thurston May 11, 2010
    Can you tell me where the part refered to as "the boot" is located ??
  • 5,911 Answers
The part number is 8182119 and can be viewed at searspartsdirect.com. Just type in your model number and look for item number 5 under the "Door and Latch Parts" heading. In addition, you may not need them, but just in case, you may consider the inner and outer bellow clamps that hold the door seal in place. This are items 6 and 14 under the same heading. Sometimes they become damaged. If you need instructions on how to replace the door bellow, the following link explains:
http://www.fixya.com/support/r385210-replacing_door_bellow_kenmore_elite
If you have any questions along the way, please let me know. I hope this helps you.
NOTE: You can find this part a little cheaper at appliancepartspros.com. Just use the "Search By Part Number" selection as your search criteria.
To keep the new bellow from mildewing, it is recommended by the manufacturer that you leave the washer door open while not in use and to periodically clean the bellow. Pull back the rubber folds in the door and make sure you do not have anything stuck that will cause odors and mildew. Small garments such as socks and underwear can commonly get stuck in this area of the door. Also, if you do not routinely use hot water, it is recommended that you run a "clean" cycle with a small amount of bleach about once a month to kill any bacteria.
Posted on Jul 01, 2009
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
Kenmore Elite HE3t 11042922200 Front Loading. F02 drain Problem
We experienced the same thing. I was able to restart and locate the noise to the water pump. After disassembling the water pump found the impeller shaft sliding out. For some reason this shaft will not stay in place. Had to order a complete pump assembly as the electric motor is not available.
Jan 15, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washing machine spin cycle slow. The clothes are still dripping wet when removed from the washer.
In my HE3T, this was indicative of the water pump going out. In its 8th year, my HE3T is now on its 3rd water pump.
Aug 02, 2009 | Kenmore Washing Machines
I am thinking about buying a 2003 kenmore elite washer and dryer for $500. they are a HE3t. are there any problems I should be aware of with this year and model.
No unusual problems. Keep it maintained properly - and you have a great washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Front Door Seal/Baffle Replacement
I need to replace a baffle from inside my Elite HE3T. Do you have directions? Only 1 came off but when I order the new one apparently it only comes in 3, so show I replace the other 2 as well? (if I can figure out how)
Of course the part did not come with any! And Sears customer service is of no help and the technical people have not responded to me.
Thanks,
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite HE3t
F2 is a drain erro. Take the 3 screws off the botom panel in the middle, bottom you will see a large white plastic looking pump. this unscrews counter clock wise. have something ready to catch the rushing water. The trap is probably full of the rubber backing or strands of the rug. After you unscrew it, there is a trap there that can be cleaned. You may have to repeat this a couple of thimes to get all of it out.
Jun 13, 2008 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
478 people viewed this question
Top Washing Machines Experts
