Question about Acer Aspire 3610 Notebook
Random starting When I start my laptop often the acer arcade delux starts. I desinstalled it but it keeps starting randomly when I start my lapop. How can I undo this?
  • 4 Answers
I recommend hunting for it in your registry. To pull up your registry you can to your start menu and in the Accessory folder should be a command prompt, it's a black screen with white letters. Type in "regedit" as is. CAUTION!!!! Be very very careful when playing around in your registry. Deleting a file from here will completely wipe it from your computer and if you're not careful you can cause irreversible harm to your computer (I've never had a problem, if that reassures you). Within your registry you can search for "arcade delux" or something like that. If you can't find the search function, hit CTRL f, and then type in what you'd like to search for. If you can find it, delete in and files with names similar to it. Restart your computer, you should be good.
Posted on Jul 01, 2009
I have an aspire 5315. Acer Arcade has disappeared and I can't seem to find a way to recover or re-install
Start -> Search -> Acer Arcade -> Start search -> when application is found single left click to highlight it -> right click on highlighted area -> send to -> Desktop (create shortcut) -> double click on new Acer Arcade` desktop icon to test the program.
If the above does not fix the problem:
start -> all programs -> accessories -> system tools -> system restore -> restore my computer to an earlier time -> next -> select a bold date on the calendar to the left and an even in the event schedule to the right that both precede/predate whatever change in settings that caused your application's icon or file directory to change configuration -> restore -> restart computer without interrupting to complete restore process -> look for the lost program in its usual place.
If none of these resolve the problem, then the programs may have accidentally been deleted by yourself or perhaps by another user, without your knowledge.
The following Site has links to download and install your lost application or, alternatively, the deluxe version:
http://komku.blogspot.com/2008/05/download-acer-arcade-deluxe-for-windows.html
Nov 22, 2011 | Acer Aspire 5315 Notebook
Im using Acer Aspire 4935. The problem is, there's a virus in my Acer Arcade Deluxe system. I've repaired once my laptop (can't go inside Window-start up) caused by this software, Arcade Deluxe. Can i...
Download and run a program called hitman pro, here is a link to download:
http://download.cnet.com/Hitman-Pro-3-32-bit/3000-2239_4-10895604.html
During boot-up keep pressing F8 this should give you safe mode options, choose "SAFE MODE WITH NETWORKING" once your have got into windows install hitman pro and use the free trial by registering the product online. Rin the software and remove any found viruses.  Re-boot the computer and go into Windows as normal all viruses should be removed.
Mar 19, 2011 | Computers & Internet
When I startup my laptop it goes straight to Arcade Deluxe how do I get back to windows
Per these pages:
http://www.theacerguy.com/forum/topic/quit-acer-arcade-deluxe
http://www.theacerguy.com/forum/topic/acer-arcade-deluxe-loading-on-startup-cant-get-to-windows
This one even tells you how to disable it in windows start up.
http://www.cybertechhelp.com/forums/showthread.php?t=182345
it says to make sure "HOLD" button is not turned on when shuting laptop down otherwise it will do what yours is doing. They are also talking about going in to safe mode and taking it out of start up. Just read the posts and you might be able to get rid of it. The one i found was towards the bottom.
Good luck.
Nov 07, 2010 | Acer Aspire 6920 Notebook PC
The Acer Arcade Deluxe Webcam is not working, but the Acer Crystal Eye Webcam is still working fine. Please, how can I solve the problem with Arcade Webcam software? I believe it stops working after some...
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
Oct 15, 2010 | Acer Aspire 55421462 Notebook
Acer Arcade Deluxe,, this application failed to start because MSVCR71.DILL was not found. Reinstalling the application may fix the problem,,,,,, how do i re-install????
Go to the web site below and download and install do as Administrator. ptf.com/acer/acer+arcade+deluxe+2.1.6319/ -
First though go to add/remove programs, locate it in the list, and click, uninstall sometimes programs will give you the option to "Repair" try this first, if no repair uninstall anyway so you'r fresh for the new install of DLed one.
Mar 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
My laptop has Acer Arcade Deluxe & appears not to work correctly
you must have selected random play. Just uncheck it and it shall be done.
Oct 02, 2009 | Computers & Internet
Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
Aug 09, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 5920 - Acer Arcade Deluxe Problem
in bios, locate windows vista and set it up to start automaticly , (default operating system)
Jan 13, 2009 | Acer Aspire 5920-6727 Notebook
In acer 5920, acer arcade installed, can not be started by hotkey
You configure the keys from the Acer Launch Manager. If you go to Start, All Programs,  Acer System you will find the manual telling you exactly how to configure it.
Dec 10, 2008 | Acer Aspire 5920-6727 Notebook
Acer Aspire 3610 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
