Question about Dryers
Replacing dryer belt and want diagram to be sure it correct
Belt seems too big and just want to be sure
    Sergeant:
    Champion:
  • 235 Answers
Put the bel around the tumbler first, then around the motor pulley, and finally put the farthest part of the belt at the pulley around the tensioner. Good luck.
Posted on Jul 01, 2009
Need diagram belt repairclinic
WE12X10009 belt part number and it's around 45 dollars
May 10, 2013 | Hotpoint NVL333EY Electric Dryer
I have a hotpoint model# dlb2880aacad. The belt broke. I bought a replacement part, giving them the model number to ensure the correct belt. It seems too long, but I am not quite sure if i am putting it on...
The belt needs to go over the tension pully too. This will make up for the slack. Check the internet under your model for diagrams. Good luck!
Sep 03, 2011 | Dryers
GE DRYER MODEL dvlr223egoww.BOUGHT NEW BELT SEEMS A LITTLE BIG.BELT WONT TUMBLE.
Hi maddy21350...
Make sure you have routed your belt correctly, if it is not properly routed then it can cause the problem you are talking about.
Go to the following webpage and see a picture of how to route your belt properly.
If you have it correctly routed the you got the wrong belt.
Please take time to rate me
http://www.expertappliance.com/dryerbeltconfiguration.html
Aug 18, 2011 | GE DVLR223 Dryers
I changed the belt, it sounds like it works now but drum does not roll????
Hi and welcome to FixYa. I am Kelly.
Things to check..
1. Belt and ilder pulley properly positioned?
Use this link to make sure you have it correct:
http://www.repairclinic.com/Dryer-Belt-Diagrams
2. Make sure the drum felt seals are not rolled / folded over. If it is folded / rolled slide the shanke of a screwdriver under the felt and rotate the drum 360 deg until it straightens out. (Front and rear seals.)
3. Make sure the drum rollers are resting in the drum groove and not behind the drum
These manuals will be a big help: (page 25)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4829abde74a34d7f85256ab000620794
and
(Page 10 below link)
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/3ffad75038c96fe4852571ca006cb80a/$FILE/L-58.pdf
Thanks for choosing FixYa,
Kelly
Apr 01, 2011 | Whirlpool Dryers
The dryer belt broke. I bought what I thought was the replacement belt but it is too large to fit the drum and tensioner pulley. Upon inspecting the motor, the shaft has a grooved portion around which...
You did not provide the model of your kenmore dryer so i can't provide the correct part # HOWEVER
you can go here:
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
and enter your model number and get exploded views of your machine, part numbers and the ability to order them directly from Sears
Feb 05, 2011 | Kenmore Dryers
1991 Maytag dryer Model #LD 68424AAL Serial # A0190126HY
Are you sure that you hooked the belt up correctly, as it sounds like you may have missed the tensioner pulley. As this will tighten the belt around the middle of the drum
Jul 20, 2010 | Maytag Dryers
Maytag electric dryer:attached belt as per directions,but is still loose,the pulley seems to not give enough tension
You can verify your belt installation by going to repairclinic.com. Click on the "Repair Help" link at the top of the page, then locate the "Dryer Belt Diagrams" link under Special Features. Refer to Diagram E under the Maytag heading. If you say you have the belt installed correctly, make sure the tension spring is still installed. I hope this helps you.
Jun 27, 2009 | Dryers
Belt too loose
Are you sure you have the belt routed correctly? You can verify by going to repairclinic.com and clicking on the "Repair Help" link at the top of the page. On the following page is a link entitled "Dryer Belt Diagrams" under the "Special Features" section. You will need to view diagram E for Maytag. NOTE: There is a tension spring on your idler. Make sure the tension spring has not come loose or fallen off. I hope this helps you. If you have questions, please let me know.
Jan 14, 2009 | Whirlpool LGR7646E Dryer
Dryers Logo
96 people viewed this question
Top Dryers Experts
Marvin
Marvin
