My 2Wire Wireless adapter connection keeps getting disconnected every 5-10 minutes(ATT U-Verse Internet Svc)Is there a better adapter to resolve my problem ? Thank you.
  • WiFiNut
    WiFiNut May 11, 2010
    Is there a cordless phone nearby possibly creating interference?
    Sniper:
  • 127 Answers
Well!! I have an answer for you.your comp is loosing the IP address. goto start - programmes - accessories - dos prompt. type ipconfig.you`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
Posted on Jul 16, 2009
New download of windows 7 won't retain or create internet connectins
Ok, this is conflicting... won't retain or create!! Doesn't it have to be created to retain it?
Did it connect before you downloaded windows 7? Exactly what happens when you try to get on the internet? Do you have the wireless switch on the laptop turned on? Do you see your wireless router? If so did you put the password in correctly? If not, it will never connect.
Jun 03, 2012 | Compaq Presario CQ62231NR Notebook
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Have ATT Uverse & it always drops the internet connection. I reset the main 2wire box weekly. The little router by my desktop is the problem - I have to disconnect & reconnect several times per...
check with 2wire website for a newer firmware version. if you are able to update to a newer version and still have problems, then your router is on its way out.
Aug 24, 2010 | 2wire (1000-400108-001) Router
I had ATT DSL w/ a linksys wireless router. I was
So, both computers are on the lan segment of 2wire? How many lan ports on 2 wire? Can you do ipconfig from the command line on both computers to see what the addresses are? In most cases, the first 3 octets xxx.yyy.zzz.### should be the same. If not, then 2wire is configured for vlan and the computers are actually on different lan segments & cannot communicate with each other.
Another thing you can do to troubleshoot is to ping each other's address.
You have to first establish there is communication between the 2 systems before troubleshooting further. Otherwise, you could be wasting a lot of time.
Jun 04, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Wireless Devices won't connect to 2Wire Modem
change the channel. this is a common problem when wireless routers are broadcasting on the same channel and at times, some cordless phones will interfer as well.
good luck
Aug 06, 2009 | 2wire HomePortal® 1800HW Router...
How do I connect a Linksys Wireless-N Model WPC600N to a 3800 HGV-B Gateway modem/wireless router use for ATT U-VERSE service?
hi! u need to setup the wireless settings of your modem/wireless router in order for the wireless network adapter see ur wireless router, check ur wireless settings first. or try to contact ur isp provider who supply the model/wireless router..
Jul 17, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Want guests to be able to use our AT&T U-Verse broadband network.
Try checking your wireless security settings to make sure you are using the correct wireless key (password).
Apr 13, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Lost connectivity to network printer when switched to ATT u-Verse
Is the printer connected via wireless? When I recently connected up a new wireless printer to my UVerse network, the printer manual said that establishing the first connection works better via an Ethernet cable directly to the Uverse router. After the printer is set up once, then I could remove the ethernet cable and connect to the printer via wireless from all my computers.
For all wireless PCs that were previously connected via wireless to dsl, you need to create a new network connection for each one, then enter the key that is listed on the side of your Uverse router when prompted. Sometimes it takes a few minutes to establish the connection.
I am amazed that ATT was so unhelpful on these issues. I was one of their first Uverse customers in Texas, and several times over the last years, techs would visit my house to solve a problem or hook something up, explaining to me as he went. That their helpful attitude is deteriorating is a real shame.
Mar 11, 2009 | Computers & Internet
Att 2wire wireless and dlink
the only thing you need for connecting 360 to wireless is an Internet connection, an 802.11G wireless router, and a wifi adapter that connects to your 360. They have these at walmart or any gaming store. I suggest giving your 2-Wire back to ATT! NOT QUALITY. Especially for gaming.
I myself prefer my box to be hard wired as lag is far less. BUT..for wifi
Get a Linksys Router and XBox brand wifi adapter for 360. Also google xbox connect. Instead of paying for LIVE
James Mac
Aug 03, 2008 | 2wire (1000-400108-001) Router
Psp internet doesn't work.
Try power cycling (turning everything off for about a minute) and connecting again.
Jul 29, 2008 | Sony PlayStation Portable (PSP) Console
Computers & Internet Logo
467 people viewed this question
David Payne
David Payne
