Question about Vizio VX32L Television
My vizio tv speakers are busted, how can i replace them
The cable guy set both the normal and HD channels in the component of tv, the sound was low so we had had to max up the volume to the highest....few days back only static sound is coming from the tv.....i tried adjusting the wires in case there was a loose connection but to no avail........can i install external speakers.....will it work ??
  • 187 Answers
You can not use external speakers unless they are part of a home theater equipment (or similar device), I recomend you to try to adjust the volume settings in your TV first.
Posted on Jul 01, 2009
We have Toshiba Regza 52XV645U. We have dish network hd channels and ever since hd channels were installed after tv plays for few hours the speakers get a funny sounds like channel sound is scrambling. It...
This sounds like what may be causing it is the cable going from the tv to the receiver box. If it is only happening on the sat channels, you know that it's not the tv. I would replace the cable, if that does not work, then it may be that the receiver needs to be replaced.
Becki Barned
DISH Network Customer Service
Dec 16, 2010 | Toshiba Regza 52XV645U LCD TV
Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
Apr 07, 2010 | Vizio VW32L 32 in. LCD HDTV
I have a VIZIO LED/LCD VF551XVT hooked up to a motorola HD DVR with a HDMI cable. When I switch from standard Def to High Def channels I lose the sound. If I turn the TV off/on the sound returns but if I...
I have the same set, same problem with one of my MOTOROLA boxes, but not with another. I have a SONY TV that works fine with this new MOTO box, but the new VIZIO does not. The audio is coming through the HDMI cable just fine, and the fact that it works when you cycle power on your TV means it's the SYNC between the TV and the BOX. I have the identical problem and am taking back the MOTO box for another one. I spoke to VIZIO for about 45 minutes trying different things. They think it's the MOTOROLA box, COX (my cable company) thinks it's this particular box, who knows.
Feb 01, 2010 | Vizio VF551XVT 55 in. HDTV
Vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Nov 11, 2009 | Vizio VA26L 26 in. LCD HDTV
CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
Can't get full screen
I have a Vizio. If I use the HDMI input I can only get normal and zoom w/ picture buttom on the remote but get full picture on all cable supplied HD channels but not on none HD channels. However, if I switch cable input, I have the TV set up with both inputs from the converter box, I am able to have the options of normal,panoramic,wide and zoom on all non HD channels. I don;t like the black bars top and bottom of the HD channels with this imput mode so I switch back to HDMI. Maybe your TV is simmilar.
Jun 28, 2009 | RCA L32WD22 32 in. LCD HDTV
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Feb 04, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
My HD only works on my video setting, but I have no sound
Ok so the sound is fine on all of the other sources,
The component is running from the cable box to the amp, and you can see it.
just take the audio Red/Whit RCA out of the cable box, and input it to Cable/TV or whatever its labled, Red White, RCA.
If you want surround, then you will have to go Coaxial((single orange RCA) or TOS out of the cable box to the Digital input on the AMP. When you use this instead of Red White RCA, your amp will automatically switch between the different types of surround depending on what the source calls for or is encoded in.
You may have to get into the amps menu and change that amps input to Digital/Coax/TOS for the surround sound.
Any more specific questions, I need the model #s.
Jan 10, 2009 | Mitsubishi WD52527 52" Projection HDTV
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Jul 16, 2008 | Vizio P4221 Television
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio VX32L Television Logo
599 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
