Question about Proteam 1400XP Bagless Upright Vacuum
Need the filter that fits on the lower left as you are standing behind the vac. (Approx 6"x3"
  • perryalanl Jul 01, 2009
    Can you tell me the number of the filter so I can purchase one.
  • yadayada
    yadayada May 11, 2010
    we are not a parts service, sorry.
  • 583 Answers
The part number is FL-x3974
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jul 02, 2009
  • 66 Answers
You should go to your retailer to see if they can find it then GREAT! But if not found you should go to home depot or lowes they will have them also
Posted on Jul 01, 2009
No water from spray on base
I had same problem. Remove all fluid from machine, I used a wet dry vac. As someone else said unscrew the 2 screws that hold the filter basket. Take out the filter basket and clean thoroughly. Find plastic hose that is now visible under basket and pull up and remove that (noticing where the slot is to put it back when finished) and pull the screen off top of hose and clean that as well. I then vacuumed out that hose with my wet dry vac. Reassembled everything and now works perfectly.
Oct 15, 2014 | Rug Doctor Mighty Pro X3 Value Pack - Blue
How do I fit the exhaust pre filter seal
We recommend having the seal you described installed by an authorized technician. Please call us at 0800 298 0298 (UK) or 1-866-693-9766 (US) so we can provide further assistance.
Best wishes,
Jessica
May 25, 2012 | Dyson DC14 Animal Bagless Upright Cyclonic...
Change the Hepa filter on Dyson dc15
Now for a proper answer haha,
Remove the bin and underneath you will find a large disc (filter holder) that the bin in sits on. This needs to be removed. Its not as easy as it should be either.
Lay the machine flat on a table and stand behind the filter and pull the two top tab points with some firmly place fingers. Once these tabs release the last bottom tab can be gently flipped off with a flat blade screwdriver from the back (behind the wand hose).
I like to peel out the old filter and clean it up with a razor blade. Once this is done you can fit a lower cost DC14 filter in and save some money. No peeling needed if you buy a DC15 filter for big bucks.
Good luck.
May 06, 2012 | Dyson DC15 All Floors - The Ball Bagless...
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
On my kenmore central vac no power unplug unit plug it back green light comes on but try turning vac on green light goes off again .
Please clarify that we are talking about the central vac LED/switch panel panel and plugging it into a 110 V wall receptacle.
If I understand when you unplug from the power source ,then plug back in the green LED comes on, looking normal ? But when you manually activate the switch on the motor housing of the vac itself the vac does not start and the LED goes out, so no green or red LED at that point?
If this is the case , Kenmore CV's built approx 5 years ago (MADE by EUREKA) and prior had a circuit board with attached cord (as opposed to detachable) which was prone to relay failure. There were several symptoms, most common was that the relay on that switch panel /circuit board would fuse on and the vac would continue to run when the hose was detached from the wall.However some I worked on from that era had exactly the same symptom you describe. If your unit is between 5 and 10 years old and this sounds accurate, you can unscrew this curved side panel relay with one philips screw. Inside on the PCB will be an L shaped black or white 24volt relay, generally rated at 10 amps. The replacement board or relay will be rated at least 24V/ 15 amps or more. If you can isolate your motor and test it separtely with a power cord or meter , the realy/board will be the only control componnet left.
If you have a small tipped soldering IRON, not a gun, you can generally find a replacement relay to rebuild the board for about $6 at an electronics parts store. Otherwise you will need to replace the control board itself, anywhere form $45 to $70 plus service call if you have a tech come out to the house, and the tech will just unscrew , detach wires and replace the board, no repair , approx 15 minutes work. This will likely cost over $100.
Please post back with your results
Oct 24, 2009 | Easy Flo EF1400 Central System Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Filter sub. for Genie 1.1hp jet vac.
C.R.Laurence model GO118 filter is available through INTRO HOME IMPROVEMENTS and AMAZON.COM. This filter is made to fit the Genie 1.1hp Jetvac. Problem solved, thanks anyway.
Sep 08, 2009 | Genie Company Vacuums
Proteam 1400XP Bagless Upright Vacuum Logo
19 people viewed this question
Top Proteam Vacuums Experts
Mike
Thatvacguy.com
ct_vacuum
Level 1 Expert
Are you a Proteam Vacuum Expert? Answer questions, earn points and help others
