Question about Mitsubishi WT-46805 46" Rear Projection Television
Mitsu 805 red grill problem
In can`t setting green grill, it`s closed on the left side, and open on the right side of the sceen, I setting the blue on advanced menu to green grill but the red not it`s enough adjust to fit, I turn off the red gun and the blue and green matched perfetly whit bad prportion imagin.
    Genius:
  • 1,694 Answers
Needs convergence amp IC's STK392-570 replaced = common repair for qualified Mits tech..........T.
Posted on Nov 22, 2007
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Hi..have a sony kp57hw40 after about 30 seconds on, the screen turns all blue..what would this be..??
most likely the blue gun is shorting out, or the ic on the neck board is defective,
or u can try turninr down the screen control for the blue gun
the controls access via the front panel,pull speaker grill off screws on sides or at bottom of grill
remove plate togain access to block of 6 controls, 3 are focus and 3 are screen brightness
center up/dwn are green
left up/dwn are red
right are blue
Apr 01, 2011 | Sony KP-57HW40 57" Rear Projection...
What are the color codes for a factory stereo system in a 2006 Nissan alttima
use at your own risk. I can not confirm these.
+12V DC Battery(Constant) Yellow/green 31 15 Amp Fuse box on left front of engine compartment, near battery. Switched Accessory Purple 6 10 Amp Fuse block behind left side of dash Power Antenna NCA Green for antenna signal Illumination Red/yellow & red/blue Steering Wheel Control Wire Red/white, green, and blue If equipped, as for Mid-Line. Left Front + Blue/white Left Front - Blue/red Right Front + White/black Right Front - Blue/black Left Rear + Green/yellow Left Rear - Black/yellow Right Rear + Blue Right Rear - Red
titleicon.gif AT SPEAKERS
Wire Function Color Note Left Front Tweeter + Blue/white Left Front Tweeter - Blue/red Right Front Tweeter + White/black Right Front Tweeter - Blue/black
Feb 20, 2011 | 2006 Nissan Altima
I have green and blue arched lines across my screen. how do i fix this
This is one of a group of sets that had bad picture tubes. A lot of them were replaced out of hand when the sets were new--I did dozens of them.
The tubes are no longer available from Sony and only available on a rebuild basis--remove the bad one and send it out for rebuild at about 300 per tube.
THERE IS AN ALTERNATIVE:
HERE IS WHAT I suggest:
With the set at first unplugged you need to remove the entire plastic grill under the front screen. It is secured in one of two ways: either 4 or more screws on the back on either side; it pulls out from the bottom and has tabs that are tucked into slots just under the screen.
The front controls/keyboard are mounted into it so if you get it free you tilt the front grill on its left side to the left; there are wire ties you can release to get more room.
The other way some versions use is there are two hidden screws at the bottom front covered with caps--remove them and lift from bottom and tilt to the left.
The idea here is to try to turn the screen controls for the green and blue (in your case) down.
With the grill out of the way you will find an inspection plate behind it dead center---remove that.
BEHIND THE INSPECTION PLATE LOCATE THE SQUARE BLACK PLASTIC BLOCK WITH SIX BLACK SHAFTS THAT ARE ADJUSTABLE.
ONE row is marked Focus (Do not touch those) You have to look closely as the controls are black and hard to read--left to right green will be in the middle and red or blue on either side of it.
With the set now turned on go to a unused video input: Locate the blue screen control( tiny letters will be b,g, red with green in the middle---turn the blue down slowly (usually to the left) until any blue lines and or blue background vanish---in your case then repeat with the green SCREEN control until any green curved lines or back ground are gone.
The idea is to lower each screen control until they just vanish--when properly done on the blank input you should only see the "VIDEO 1" ETC in green, with no other color in the background. Do it slowly and it should take less than 1/4 of a turn for this.
If it works you should now have a good black and white picture.
Since these sets have a history of this kind of problem you may only be buying some time---I have done it on dozens of sets and many last more than a year or more without repeat of the problem.
This gives you more life from the set and time to save up to replace it.
Let me know before you attempt this if you have any questions.
If this information told you something you did not know, rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 13, 2010 | Sony KP-57WS520 57" Rear Projection...
SONY PROJECTION TV TROUBLE SHOOTING BLUE SCREEN
This was one of several Sony models that had bad picture tubes--the set uses a red, green, and blue tube.
There is something easy you can try that may help you get some more life from the set.
SONY SCREEN ADJUSTMENT:
Here is what you need to do.
1.) You need to remove the entire plastic piece below the front of the screen. You most likely will find 3 screws on either side in back that you have to remove.
2.) The grill will not come out easy, pull from one side and then when it starts to come loose from the other side(there are several plastic pegs that hold it in.) Then from the bottom pull out( most of these sets have square plastic tabs at the top that tuck in.)
3.) With the grill removed locate the inspection plate behind it (it usually has 6 screws.) You will have to tilt the grill to the left and on its side as several cables are connected to it--they are held in place with trash bag like ties that you can release to get some room.
4.) With the inspection plate removed you will see a fairly small (about 3 inch square) BLACK PLASTIC BLOCK WITH SIX CONTROLS-usually they are marked with whiteout so someone can tell if they have been adjusted.
5.) You need to look very close at the block with a flashlight----usually the top three controls are FOCUS--don't touch those.
The lower three are usually marked Screen and if you look very close you will see b, g, r(blue green red)
6.)Usually the GREEN will be in the middle.
7.) Once you locate the BLUE screen control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the Blue screen down until the set stays on and then very slowly turn it up until you see a slightly Blue screen with or without diagonal trace lines----turn it down slowly until the Blue screen and trace lines just disappear.
Let me know if you get it to work--Like I said if it is shutting down you may have to slowly turn the screen down a few times to get it to stay on.
If it works you may only be buying some time--if the blue tube caused this it may return at some point.
If all this information has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 20, 2009 | Sony KP-51HW40 51" Rear Projection...
My sony kp-57ws500 turns on and works fine for about 15 min but then fades to blue then goes all blue. i took the back off and when it starts to fade to blue the green tube and red tube fade off. what...
These sets had problems with bad picture tubes that cause this exact problem, but there is something you can try that may help you get some more use out of the set.
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Here is what you need to do.
7.) Once you locate the BLUE control have the set on and turn it down--if the set is shutting down you may have only a few seconds to try to turn it down---usually to the left with the Screen control.
8.) Best way to do this if the set is on is on a video input clip_image001.gif with nothing connected--you turn the blue down until the set stays on and then very slowly turn it up until you see a slightly blue screen with or without diagonal trace lines----turn it down slowly until the blue screen and trace lines just disappear.
If this works you may only be buying some time and if it is the tube sooner or later it may return with the same problem.
If this has helped you rate this solution as I do this here for free.
Regards, SD TECH
Dec 19, 2009 | Televison & Video
Wiring stereo probe gt turbo 1989
1989 Ford Probe Stereo Wiring Constant 12V+ Blue/Red Switched 12V+ Blue/White Ground Chassis Illumination Light Green/Black Dimmer n/a Antenna Trigger White Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Orange Left Front (-) Blue/Black Right Front (+) Blue Right Front (-) Blue/Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Green/Orange Left Rear (-) Green/Red Right Rear (+) Green/Blue Right Rear (-) Green
Apr 25, 2009 | Car Audio & Video
Puzzles 130 Too Many Queens 5 --- 132 Princess's Escape
puzzle 130:Assuming on a chess board 8x8 that each square is numbered 1-64 top left to right.Place a queen on each of these squares 3,13,18,32,33,47,52 and 62 bobs yer uncle
Mar 09, 2009 | Nintendo Professor Layton & the Curious...
Plymouth voyager
Hi Marlon,
Not a whole I can do to help. What I can do is refer you to go get a Chilton, or Haynes manual thac voers your Plymouth Voyager. They have schematics with wire colors labeled.You will have a good shot at figuring out which wire is which.
Nov 24, 2007 | Car Audio & Video
Mitsubishi WT-46805 46" Rear Projection Television Logo
46 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
