Question about Jeep AM/FM Cassette with CD Changer Controls - Upgrade Swap
How to remove manifold in 1996 jeep grand cherokee loredo?
I don't know how to remove manifold from my jeep , it is a 96 and 4.0l, neeed to put new one on. also everytime i slow down the oil presure drops what can cause that? please e-mail me back,
Ok, the manifold comes off with eight bolts, four on top and four on the bottom. they are 9/16 head bolts so use a 9/16 short socket for the bottom, you will need a 3/8 extension for the top bolts about six inches long and make sure you remove all vacuum lines, fuel lines and take the exhaust pipe apart. the manifold should pull out after that. i recommend you take the bottom bolts out first as they are the hardest to get to.
Helpful in georgia...
Posted on Nov 20, 2007
  • bap110378 Nov 20, 2007
    as far as the oil pressure is concerned, the oil pressure switch is probably bad. that would cause the oil pressure to read low. the oil pressure switch is located Under hood, passenger side, lower engine area, above oil pan, mounted in engine block.
I need to know how to replace a heater core in 1996 jeep grand cherokee loredo
the dash has to be remove on jeeps and dodge,it's alot of work and thakes about 4 hours to replace good luck.
Nov 08, 2012 | 1996 Jeep Grand Cherokee
Can't locate body control modile for 1996 grand cherokee loredo
BCM is under the left dash near the steering column....
Hope this helps.
Sep 15, 2011 | 1996 Jeep Grand Cherokee
just below the exhaust manifold on the drivers side of the jeep.... u will need to go underneath the jeep an may even have to remove the water shield that is under the front of the jeep..
Jul 16, 2011 | 1999 Jeep Grand Cherokee
I have a 1996 grand Cherokee loredo. I thought I had a battery problem put new one in and still drains. I then got the alternator checked it is good. What else could cause the Jeep not to run. Could it be...
The starter on your Jeep could be worn...allowing it to drain the battery when not running...this is hard to confirm...but usually causes the problem like you are having...:)
Dec 13, 2010 | 1996 Jeep Grand Cherokee
Where is the upstream oxygen sensor located on a 96 jeep cherokee grand loredo and how do you get to it
It should be on the exhaust pipe (looks like part of a spark plug with a wire coming out of it) since it's "upstream" that means you have two. The one you want is the one closest to the engine end of the pipe. How to get to it? Any way you can, what ever is easiest. One thing though...when putting the new one in, definitely use anti-seize compound on the threads or the next time you need to remove it, you won't be able to.
Apr 03, 2010 | 1996 Jeep Grand Cherokee
The security light is the factory alarm. Does this come on while driving?
Oct 24, 2008 | 1996 Jeep Grand Cherokee
1996 grand cherokee bumper
there is a trim panel on top of rear bumper if you look underneath there are clips that go through metal bumper also there are 4 plastic fasteners that will need to be replaced after removing best to get clips at dealer cheap enough hope this helps ya
Jul 07, 2008 | 1996 Jeep Grand Cherokee
Car Audio & Video Logo
219 people viewed this question
Top Jeep Car Audio & Video Experts
xxxxxx xxx
Tom Chichester
Oloyede Monsuru
Are you a Jeep Car Audio and Video Expert? Answer questions, earn points and help others
