Question about Compaq Presario CQ60-220US PC Laptop
Where is the THT LCD system located and how can i change it
My icons changed in to kmp player, how can i change it back ,i cant able to open tht if i try to open tht it display tht it is a corraupted file
Right click on file, i.e. your WORD doc file, select "open with", select "open with program" at end of listing, even if WORD appears, from the listing select WORD and checkmark where ir say "use always this program to open files". Repeat for each extension to updated correct association
Another way might be Restore System to a point before this mismatch happened
Oct 03, 2015 | Lenovo 3000 N200 Intel Pentium Dual Core...
Our 2009 Sony Bravia is flashing a standby light and keeps turning off after 1 minute. Any ideas?
u shld chek in the settin ....it might b the pblm in ur tv settin..therr ll b one signl in ur tv emot tht shows th i+ symbol click tht n go through tht ..
Mar 10, 2010 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Brake lights went out, changed bulbs, checked fuse, still wont work
You have to check the brake light switch which should be around the brake pedal on the upperside.
Ones located rremove the wires tht go to the switch and jump them by using a piece of wire, thn check if the brake lights come 'on'. If they do , thn its the switch tht may need replacing or even sometimes adjusting inorder to operate.
Hope this helps.
May 10, 2009 | 2002 Nissan Xterra
About Internet Speed...
in general this utilities change some generic settings and/or clean your cache from your browser...
no utilities exist that will give you more speed than your connection.
Mar 15, 2009 | Computers & Internet
Help
Ok, put in the disk and select install, during the install you will get an option to format
Jan 25, 2009 | Microsoft Windows XP Professional
Usb device not recongized showing this error in my pendrive
wat is the error msg tht u get?? Did tht pen drive came with a cd......try connecting the pendrive to all usb ports on the system....if tht doesnt wrk, go to device manager & then uninstall all usb root hub under usb option.....restart system thn chk
Jul 22, 2008 | Toshiba Satellite A135-S2276 Notebook
Hair in my monitor
dam man tht sux, well u basically have to get inside your system to take it out. take off the plastic surroundong the screen and get to the lcd screen then take it out, really hard, i would get some professional if u really wanted it out.
Apr 07, 2008 | Toshiba Satellite A105 Notebook
MONITOR FREEZE
Hi
You need to hold down the monitor menu button and you will get the msg on the monitor tht the OSD menu is unlocked....
It will take about 10-15 seconds....
Feb 25, 2008 | Gateway FPD2275W LCD Monitor
Compaq Presario CQ60-220US PC Laptop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
