Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
11 horse briggs will not shut off tried everthing something in the electrical i have three in line fuses so i can start it with the key start theres no pull rope to start it any segestions?
  • 218 Answers
Hi..my name is Keith...and if you can start the engine..and then pull the plug off the back of the ignition switch..and it cuts it off..then you probably need a new ignition switch..i hope this will help..if not please write me back
Posted on Jul 02, 2009
What causes a lot of gas in oil on 8.5hp B&S
This would be caused by a sticky needle valve on the float in the carburetor.You have three cures 1. remove and clean the carburetor internally. 2. replace the carburetor with a new one. 3. or most simply buy and install a fuel shut off valve and turn it off when not in use. make sure you change the oil 1 4 ID LINE GAS FUEL SHUT OFF VALVE TECUMSEH BRIGGS
Jun 03, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Electric start on a 700 series briggs & stratton engine power-propelled, electric start doesn't work
All electric start newer mowers have an in line fuse 20 or 30 amp installed in the wiring harness just before the battery. Some have 2 fuses, check for blown fuse.
May 27, 2014 | Garden
Getting fuel in oil on 19hp b&s motor. Cleaned carb and drained oil, fresh oil and started motor, motor ran for 3 or 4 minutes then had to use a little choke to keep running and then it started...
How long did it take to do this job..did you clean the the carb first...then the oil or vise versa...the reason I as is ma y if these motors are equipped with an electric valve on the carb that go bad or stuck allowing the gas to continue flowing after shut down eventually in the intake valves and into the crankcase...causing smoke and high crankcase pressure and out the carb and exhaust...no use changing it WILL happen again..the fix is simple put an inline gas shut off and shut it off if only shut down for minutes...happened to my 18 horse Briggs...just shut it off every time you turn the engine off..Hope this helps..good luck..
Sep 08, 2011 | Briggs & Stratton Briggs Stratton Vanguard...
27 horse power briggs on poulan pro. It smokes,
Very likely, the piston rings are badly worn or stuck. There may even be a small hole in a piston. In any case, you will need a major tear-down to repair this one. This is usually caused by lax oil-changes. It might be better to purchase a replacement engine than try to fix everything that could be wrong with the present unit if you take into account parts and labor. Hope this helps!
May 24, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Changing motors
i think what you are describing is the fuel shut off solenoid. i am not sure how it wires up but the workaround i have used is to replace the carb with an older model,same approx engine. they dont retool the blocks. find an older model 12 1/2 horse without them you should be fine.the wires if i remember right is gray and black from the solenoid
Jul 22, 2009 | Briggs & Stratton Garden
I have a Toro Wheel horse, 13-horse Briggs & stratton and have zero spark what do I look for. I replaced the spark plug and have a full charged battery. I know little about engines so if you suggest i...
Usually when you have zero spark, it's one of 3 things. Either there's a shutoff that is trying to shut it off when it's not supposed to, the coil is bad, or the flywheel key is sheared.
Jul 11, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
74 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
