Question about Fuji FinePix S3500 Digital Camera
Focus problem When i switch on the camera it does not focus as it should and i have to use the zoom to get anywhere near focus
  • Anonymous Nov 15, 2007
    Excatly the same problem - need to zoom in and out several times to get a focus - is an occasional fault only, not constant. Thought it may have been a battery problem but still there with newly charged ones.
    Problem Solver:
  • 8 Answers
Guys
That S3500 is a defective product,get in contac to them idiots at Fuji. My S3500 was rarely used and it stopped working suddenly.
Posted on Jan 30, 2008
Hi ,i have a tamton 70-mm that it stop focusing manuakly whe n i was using it yesterday,may i ask how it would happent,and how much would cost to fix it?
Do you really mean it stopped focusing manually, or did it stop auto-focusing? If it is the latter, check the M/AF switch on the lens near the camera body and make sure it is set to AF.
Sep 21, 2011 | Tamron 70-300mm f/4-5.6 Di Zoom Lens for...
My lens will not focus. Pictures are all coming out blurry no matter what setting I have the camera on, and no matter how much I zoom in or nout.
Hi
You know sometimes the lens will not focus if you have a physical damage etc., first of all i would like to clarify some points.
1. Did you place your camera near to a strong magnetic area?
2. Did you drop the camera?
3. Did you use Zoom in Zoom-out continuously at the same time?
for the first point i am sure it was exposed to strong Magnetic field, as and when it is exposed the coil of the zoom lens which move the lens in and out will get out of place and makes it impossible to maintain focus. If so then better is to open the camera and re-adjust the lens. But if you are confident to put it back then open it or try to slowly wiggle the camera and check if it gets better.
Jul 18, 2011 | Kodak EasyShare Z915 Digital Camera
Picture are out of focus Is lens housing suppost
There's a slide switch on the end of the camera, near the USB socket. Make sure it's in the proper position. The flower position is for taking pictures of objects close to the camera, the mountain position is for other pictures.
Feb 09, 2011 | Vivitar ViviCam 5024 Digital Camera
System Error (Focus)
The systems control board has detected a problem with the auto focus lens, the focus is controlled by a tiny motor that has jammed or there is a mechanical issue with the camera lens. It will require a technician that is highly skilled to deal with the situation, but the repair cost would probably not be justified.
Jan 12, 2011 | Panasonic DMC-FX37 Digital Camera
When i turn on my camera to take a pic it is blurry but if i zoom the lens all the way close to the object it takes a good pic.
Your auto-focus is not working. Inside the camera is a motor that adjusts the lens to focus on an object automatically. It is currently stuck to "close" or near focus. However, it doesn't go far focus. Check the focus functions of you camera - try to use manual focus.
Dec 01, 2010 | General Electric A735 Digital Camera
Autofocus slow from far to near, or from near to far when take pics.
Try using the limit switch to cut the focus time down, depends on your subject distance, but it may help
Dec 07, 2009 | Nikon AF-S Zoom Nikkor 80-200mm f/2.8D...
HELPPP!! My camera will not focus when zooming at all.
is it possible that the focus switch on the left side of the lenses is set to macro, or manual focus? That could make your camera "go blind".
Vladimir Z
May 20, 2009 | Panasonic Lumix DMC-FZ50K Digital Camera
Soft focus s500
It is a bad lens very common issue with casio send it in for repair or get one off ebay with a broke lcd lens might be sill ok.I fix these cams all the time with bad lenses.
Nov 08, 2007 | Casio Exilim EX-S500 Digital Camera
Strange mechanical sound from lens area
Cele, The noise you're hearing is perfectly normal. This generation camera uses a piezo electric focus mechanism to operate the lens. You will notice that the noise goes away if the camera is left alone for a moment while focused on a non moving object, this is because the focus adjustment is made and then the piezo circuit shuts down to conserve battery power. You should have no problems with this camera, it is very reliable. Hope this helps you. Joe Weibel customelectronics.org
Aug 31, 2006 | Sony Cyber-Shot DSC-W5 Digital Camera
Zoom Problem
There are two components to a camera lense. One adjusts the final lense distance from the CCD imaging chip the other adjusts the distance between the lenses in the assembly (which zooms the image in and out). It sounds like something inside the lense came loose and when you zoom the lense the focal lense is moving with the rest. The lense will probably have to be replaced if it cannot be taken apart. Odds are something is broken inside anyway. This could be something you might be capable of, I have no way of knowing. If you do not think you are up to the task, have a reputable repair shop do it. Cost should not be excessive. I would think less than $100 US plus the cost of the part. Good luck.
Jun 16, 2006 | Samsung VP-D103i Mini DV Digital Camcorder
Fuji FinePix S3500 Digital Camera Logo
74 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
